rancer Posted March 15, 2011 Share Posted March 15, 2011 Getting a 'clunking' sound when the front nearside wheel goes into a pothole at anything other than crawler speeds. Suspension looks fine so im thinking its a drop link, I vaguely recall having read about this being a problem with the Zeds? Whats the rough costing for a new set of drop links? Is it possible to check visibly? (haven't even tried yet) And I guess when it comes to replacing them then or :pmr35lee: will be the answer? Finally, is it an easy job? The fronts were easy on the Celica but the rears were a right pain! Quote Link to comment Share on other sites More sharing options...
MrLizard Posted March 15, 2011 Share Posted March 15, 2011 i changed my own ages ago, broke a spanner on the rear right but only because it was tight, not a difficult job. i got some from z1auto in the states but that might be a bit ott for road use, suspect Alex can help you out. Quote Link to comment Share on other sites More sharing options...
rancer Posted March 15, 2011 Author Share Posted March 15, 2011 Cheers - just read up on the Powergrid ones from Z1autos, they are probably more than I require. Once I confirm the drop links are the problem ill see about getting some from here - better than giving Nissan my money Quote Link to comment Share on other sites More sharing options...
MrLizard Posted March 15, 2011 Share Posted March 15, 2011 if i knew where my old ones were id try and help you out but your probably better getting newer ones Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted March 15, 2011 Share Posted March 15, 2011 New oem ARB drop links in stock. New PowerGrid also in stock. Alex. Quote Link to comment Share on other sites More sharing options...
rancer Posted March 15, 2011 Author Share Posted March 15, 2011 Cheers Alex - whats the costs? Also, is there an easy way to visually check? Quote Link to comment Share on other sites More sharing options...
danpollard Posted March 26, 2011 Share Posted March 26, 2011 Did you find out if this was the problem? I've got similar symptoms and that's all I can think of, but it was recently serviced by Nissan and they'd just ticked the box to say checked and fine. Personally, I'm dubious they did! Quote Link to comment Share on other sites More sharing options...
Mark@Abbey m/s Posted March 27, 2011 Share Posted March 27, 2011 We have developed our own drop links. We use heavy duty sealed joints. Far better quality than the stock links and more robust against the british weather than some of the aftermarket kts around. If you look in our own Abbey part of this forum you see pictures and prices (I think I have updated the price for 20% VAT) Quote Link to comment Share on other sites More sharing options...
