Michael robinson Posted March 15, 2011 Share Posted March 15, 2011 Sorry to always seem to shout for help but this time it's serious Here's the story I was taking my girlfriend to a job interview and half way ther I pulled up to a set of lights and the car just died, I tried to restart it but nothing . Then tried again and electric came back could here relay click but nothing, got a few kids from the street to push me and tried to bump start it, it started the first time for about 10second then died and wouldn't start after that. So phoned AA and he turned up he pluged his dynostic set in but couldn't get it to linked up. We tried linking the battery to his booster pack still nothing. he also tried reset procedures and play around pressing buttons on the key fob (must be reset procedures for immobiliser) - immobiliser had consant red light . Then he linked the battery to the engine casing and it turns over but its not getting sparks from my plugs and don't think am getting fuel. (cooling fan is running full belt when ignitions on) anyway after a while he give up and i got recovered to my home Two days on i have tested all fuses and relays and all are fine the immobiliser light is back to normal (flashing red) and cooling fans dose not run when ignition is turned on. when i turn the ignition key the engine/oil/battery lights stay on and i hear a clicking noise ( battery light flashes with clicking noise) - i have recharged battery and it seems to be holding its voltage well. i got a hold of a obd2 code reader off one of my friends and the car still wont work connect to the unit . 2days on - i removed all connectors, fuses, relays , tested them and put them back . tryed to start and we have life everything back to normal like nothing happened , i drove it straight to the nissan garage and got a free diagnostic check (friends ) the diagnotic connected straight away but no fault logged . it worked for 2 days perfect till i was driving home then the engine light came on and it started spluttering kept running for about 200 yard then died . got it recovered and taken it to nissan as i couldnt work on it anymore than i did plus couldnt check underneath due to body kit . anyway two days on that nissan has had it they come back saying that they cant find anything wrong so far and they think its an ecu fault so are sending it to be tested . i thought it was a loose earth wire or my bendix in the starting motor or the hole starting motor that would be at fault but thhey seem to think other wise what you guys and girls think ? Quote Link to comment Share on other sites More sharing options...
Zugara Posted March 15, 2011 Share Posted March 15, 2011 Battery in the key fob might be on its way out. Quote Link to comment Share on other sites More sharing options...
Sarnie Posted March 15, 2011 Share Posted March 15, 2011 Sounds like a dead battery...... Quote Link to comment Share on other sites More sharing options...
Michael robinson Posted March 15, 2011 Author Share Posted March 15, 2011 Light work , radio works , seats move evrything comes on just nothing once u turn the key . If you link the battery to the engine casing it turns over (ie starting motor turns) but nothing else happens no spark etc Quote Link to comment Share on other sites More sharing options...
chocohercules Posted April 10, 2011 Share Posted April 10, 2011 Hi Nichael did you manage to sort out your starting issues? As im having similar problems Quote Link to comment Share on other sites More sharing options...
Michael robinson Posted April 10, 2011 Author Share Posted April 10, 2011 Not yet it is still in Nissan but should get a result this week , they have sent my ecu away to be tested so will update when I hear from them this week Quote Link to comment Share on other sites More sharing options...
Michael robinson Posted April 12, 2011 Author Share Posted April 12, 2011 Just got my results from ecu tester it is the ecu at fault (the feed for the start relay) so will get it back tomorro and will inform Nissan of there findings so they can test the relay and everything associated with that part of the system . The cost of an ecu to be reconditioned is £210 Hope this helps Will update again tomorro Quote Link to comment Share on other sites More sharing options...
Ebized Posted April 12, 2011 Share Posted April 12, 2011 Faulty earth strap has been known to cause these problems Quote Link to comment Share on other sites More sharing options...
chocohercules Posted April 12, 2011 Share Posted April 12, 2011 Hi Ebized, pardon me for sounding Stupid but what is the Earth Strap? Is it the bar that goes across the top of the battery? Quote Link to comment Share on other sites More sharing options...
Michael robinson Posted April 12, 2011 Author Share Posted April 12, 2011 If you take the cover off your battery cubical you will see the negative is just bolted to the engine body on a bar of terminals form that there are loads of wires linked to most parts in your engine bay ie engine casing etc Quote Link to comment Share on other sites More sharing options...
Ebized Posted April 12, 2011 Share Posted April 12, 2011 Hi Ebized, pardon me for sounding Stupid but what is the Earth Strap? Is it the bar that goes across the top of the battery? See the posts at the bottom of this thread: viewtopic.php?f=10&t=41995&hilit=engine+earth Having a 370 now I don't honestly know where the engine earth strap fits to the chassis on the 350. The rock of the engine over the years can break or nearly break the flexible strap. No doubt you checked the connections on the battery and the earth there to the chassis but your car's symptons point to the engine earth strap IMHO Quote Link to comment Share on other sites More sharing options...
SteveW Posted April 13, 2011 Share Posted April 13, 2011 It really is amazing what an earth strap broken or poorly connected can do. Car just behaves very very irratically. I had the same exact issue with an old car. A new earth strap sorted all my problems. Good luck , hope its something simple. Quote Link to comment Share on other sites More sharing options...
HaydnH Posted April 13, 2011 Share Posted April 13, 2011 It really is amazing what an earth strap broken or poorly connected can do.Car just behaves very very irratically. I had the same exact issue with an old car. A new earth strap sorted all my problems. Good luck , hope its something simple. The current from the engine will always try and find the easiest route to ground, if the earth strap is faulty god knows where the next route would be on a Z and what that current will be affecting (actually Alex would probably know... but same thing on this forum I guess!). I know the next simplest route to ground on a '2 is through the throttle cable which burns if you keep trying to start the car with a faulty earth strap. Quote Link to comment Share on other sites More sharing options...
Michael robinson Posted April 20, 2011 Author Share Posted April 20, 2011 Finally after a month of the monkeys at Nissan playing with my car they say they have found and rectified the fault They said it was the coils on the car had broke down and caused a direct short which resulted in all the other faults . So hopefully get the car back and pay up the horrendous bill . Having mixed emotions at the min . Anyway going to ask for a break down of cost and al post it on here so you'd can have a laugh Quote Link to comment Share on other sites More sharing options...
