H5 Posted November 5, 2006 Share Posted November 5, 2006 I've done a search on here and I can only see Dorian's guide on the front bumper removal which is for JDM cars. Problem being I have headlight washers and the guide doesn't cover what you're supposed to do with them. Anyone done this and got a guide or suggestion? Quote Link to comment Share on other sites More sharing options...
Removed Posted November 5, 2006 Share Posted November 5, 2006 easy enough... pop the top off, once you have the bumper off you'll see what to do from the inside Quote Link to comment Share on other sites More sharing options...
H5 Posted November 5, 2006 Author Share Posted November 5, 2006 easy enough... pop the top off, once you have the bumper off you'll see what to do from the inside How do you mean pop the top off Val? I've got to the point where I've undone the two bolts in the corners, and the screw in the wheel arch. Then the plastic spread fasteners under the front edge of the bonnet. But I've still got the washer heads stopping me from getting it off. IIRC these cost about £200 to replace so don't want to break them!! Ideas? Quote Link to comment Share on other sites More sharing options...
Removed Posted November 5, 2006 Share Posted November 5, 2006 they come off from the outside! hard to explain, the tops just come off! then once you have all the bolts off for the bumper, you'll see how to take the mechanisms off the bumper, from the inside Quote Link to comment Share on other sites More sharing options...
