Brake help please!
t3dcf
I know I have seen this somewhere in here - but for the life of me I cant find the answer Im looking for.
I have just replaced all pads on my z - think I have apec pads all round. Now my issue is a really annoying brake squeal under use! Any ideas - I have taken back to garage a few times, brakes off - edge filed down to let brake dust escape, more copper grease etc - Does anyone have any ideas? I remember seeing something about alloy cleaner? but dont want to just guess......
Help! :headhurt:
Ill have a look - but dont think so....is that probably where the noise is coming from then....not from the pad on the disk?? If i havent got these plates can they be retro bought/fitted?
you should have had them on the original pads, but on my EBC pads they came with the new pads in the box :)
I got some red stuff pads fitted at a local garage and they said they didn't have the metal shims on them that made a sound when the pads were low. Not a problem I thought, but now I'm thinking this may be why mine are squeeling still 2 months later? :wacko:
They only squeal when braking gently at slow speed, but it's still annoying :thumbdown:
try a bit of copperslip on the rear of the pads that should stop it :thumbs:
Thanks for all the replies!! Ive not got the slip pads and not sure where to get them... ive got the same issue as Traktion so I think i will have to get the garage to try the copperslip on the back of the pads!! (just a final thought (much like Jerry Springer) why would putting the copperslip on the rear of the pads make a difference...I thought the noise came as i braked.i.e. when the pads touch the disk?)
noise comes from the rear of the pads making contact with the caliper pistons, high frequency buzz is what you get
