How do I change my headlight bulb
pooler350
Best way is to remove the wheel, peel back the arch liner and them remove the 5" grey disc from the back to the headlight to allow access to the bulb. :)
+1
Nissan (sigh) says:
Remove headlamp washer nozzles
Remove front bumper
Remove headlamp unit
(Finally) replace bulb
Reassemble all above.
Naturally, any such work should be carried out by a qualified mechanic...
So a good hours work there... £50-£60 labour down the local Nissan stealers? Way to go guys...
Or you can do it the Nissan way and remove the wing. :surrender:
It was never going to be easy.
