Couple of questions
MadGrip
Ive had my Zed about 4 weeks now, not had one for 4 years and its great to be back behind the wheel.
The car has had a few things done to it, but the thins I'd like to know are, are you able to tell visually if its had a plenum spacer fitted? if so, what should I be looking for? And secondly, whats the best way to give the pop charger a good clean?
Cheers
Phil
If you look down the side of the engine on the R/H you will clearly see if a spacer has been fitted between the upper plenum and the lower collector.
Regarding the filter, just remove it and give it a good blow out with an air supply and and then just lightly reoil with a fine mist. You can use that coloured stuff if you fancy a colour change. :lol:
