Ozz Posted March 19, 2011 Share Posted March 19, 2011 Just fitted a set as my old ones were terrible, seem to be pretty good for the money. Shame to lose the wind deflector on the old ones but I guess not needed with these. Quote Link to comment Share on other sites More sharing options...
CrumbMC Posted March 21, 2011 Share Posted March 21, 2011 mine came on friday and fitted them straight away. seem to be an improvement on the bouncey, skitty ones i had on before. And they look much nicer. Thanks for the reccomendation Quote Link to comment Share on other sites More sharing options...
jollyranchers Posted March 22, 2011 Share Posted March 22, 2011 2min fitting quote] i must be completely retarded as the brief attempt i had before i cant get mine to fit did you use all the plastic clips ? i can get the wiper on but cant see how both plastic inserts go in what am i doing wrong !!! Quote Link to comment Share on other sites More sharing options...
magic84 Posted March 22, 2011 Share Posted March 22, 2011 i bought a set of these a while ago, very good for the money and at low speed. but when driving at speed they do skip a little on the down stoke as there are no wind deflectors. so i use them along with rian ex. mine are being to go funny on the backs, (looks like dryed salt if you know what i mean). so will be getting some more soon. but for the money i you cant go wrong even if you change them often. Quote Link to comment Share on other sites More sharing options...
flyboy Posted March 23, 2011 Author Share Posted March 23, 2011 2min fitting quote] i must be completely retarded as the brief attempt i had before i cant get mine to fit did you use all the plastic clips ? i can get the wiper on but cant see how both plastic inserts go in what am i doing wrong !!! Mine were just a straight swap no clips included or needed I should contact the seller and make sure he has sent you the right ones Quote Link to comment Share on other sites More sharing options...
Ozz Posted March 23, 2011 Share Posted March 23, 2011 Yup mine straight swap as well. A little clip you press underneath the old ones then they kind of rotate out. Lift the plastic cover on the new ones, slot in, pull back, job done. About 1 minutes work! Tried them in light rain, I can actually see properly now! Quote Link to comment Share on other sites More sharing options...
jollyranchers Posted March 23, 2011 Share Posted March 23, 2011 see video - did you all do this ? http://www.wiperblades.co.uk/fitting-gu ... er-blades/ this i can do but it did not feel like a very good fit , my blades also came with another clip which fits under the hinged flap which i could not get to fit with the z wipers unless this is just a universal type clip Quote Link to comment Share on other sites More sharing options...
flyboy Posted March 23, 2011 Author Share Posted March 23, 2011 Yup, Just do what the video shows. Exactly that No More No Less 2 mins or less Just make sure when you put the new ones on you push ( or pull ) back until it click and locks into place then lower the flapy thing..... Quote Link to comment Share on other sites More sharing options...
