stuey Posted November 2, 2006 Share Posted November 2, 2006 my airbag warning light came on this morning and now it flashes all the time ... .. how do i reset it or do i have to take it to the stealers..... thanks in advance... Quote Link to comment Share on other sites More sharing options...
monkfish Posted November 2, 2006 Share Posted November 2, 2006 Here's the guide for resetting it: http://www.350z-uk.com/forum/viewtopic.php?t=3279 Quote Link to comment Share on other sites More sharing options...
stuey Posted November 2, 2006 Author Share Posted November 2, 2006 cool.......... i did that and it lasts about 10 minutes till it comes back on ...... any suggestions,...?? Quote Link to comment Share on other sites More sharing options...
lomoto Posted November 2, 2006 Share Posted November 2, 2006 cool.......... i did that and it lasts about 10 minutes till it comes back on ...... any suggestions,...?? try disconnecting the battery for 30secs or so, see if that will reset it.. Quote Link to comment Share on other sites More sharing options...
stuey Posted November 2, 2006 Author Share Posted November 2, 2006 ok will do.............. will keep you posted... Quote Link to comment Share on other sites More sharing options...
lomoto Posted November 2, 2006 Share Posted November 2, 2006 ok will do.............. will keep you posted... just thought have you been hovering under the seats recently and dislodged a connector?? Quote Link to comment Share on other sites More sharing options...
stuey Posted November 3, 2006 Author Share Posted November 3, 2006 no i havnt lomoto but i will check the connections anyway...... tried disconnecting the battery but still the same... Quote Link to comment Share on other sites More sharing options...
lomoto Posted November 3, 2006 Share Posted November 3, 2006 no i havnt lomoto but i will check the connections anyway...... tried disconnecting the battery but still the same... hate to say it , BUT ..may be a trip to dealers for a reset Quote Link to comment Share on other sites More sharing options...
M13KYF Posted November 3, 2006 Share Posted November 3, 2006 remember to lower the windows before disconnecting the battery Quote Link to comment Share on other sites More sharing options...
Leenx Posted November 3, 2006 Share Posted November 3, 2006 Why lower the windows? Quote Link to comment Share on other sites More sharing options...
M13KYF Posted November 3, 2006 Share Posted November 3, 2006 it's to do with reseting window positions they auto drop slightly when opening/ closing , if the battery is disconnected the glass will strike the bodywork Quote Link to comment Share on other sites More sharing options...
H5 Posted November 3, 2006 Share Posted November 3, 2006 Mine was doing this and the dealer explained what happens. The circuit tests itself by sending a signal on start up that should show all being well. The Zed (like all other Nissans) uses cheap couplers for this that over time get loose or dislodged and therefore leave the light on. This info is stored on the car's brain and the dealer can tell where the sensor is failing and check the connector. Don't see why it should be a problem to sort for you. IMO, it's the safety system and would get it checked asap. If someone hits the car you'll be wanting them to go off if they need too!! Quote Link to comment Share on other sites More sharing options...
stuey Posted November 3, 2006 Author Share Posted November 3, 2006 hmmmm ive tried eveything suggested so far with no success i think my next stop is at the main stealers.... ........ just hope they dont charge too much!! Quote Link to comment Share on other sites More sharing options...
live2themaxuk Posted November 3, 2006 Share Posted November 3, 2006 Anything related to the seatbelt tensioners? unplugged maybe? J Quote Link to comment Share on other sites More sharing options...
stuey Posted November 6, 2006 Author Share Posted November 6, 2006 took car to the stealers today and they did a diagnostic check on it.... they sed its the seatbelt tensioner in the drivers seat and i need a new one .............. £404.............. jeeeeezzzz....... Quote Link to comment Share on other sites More sharing options...
live2themaxuk Posted November 6, 2006 Share Posted November 6, 2006 breakers m8ty, has to be. . . . .thats daylight robbery Jamie Quote Link to comment Share on other sites More sharing options...
stuey Posted November 6, 2006 Author Share Posted November 6, 2006 well im open to suggestions if you know where i can go to get one..... Quote Link to comment Share on other sites More sharing options...
live2themaxuk Posted November 6, 2006 Share Posted November 6, 2006 i dont m8 but there are loads of breakers online. you write them you requirements and they phone you back. think there was a recommendation of a breakers somewhere else on the forum with regards to another part someone was after. . . . . loads of google though Jamie Quote Link to comment Share on other sites More sharing options...
lomoto Posted November 6, 2006 Share Posted November 6, 2006 well im open to suggestions if you know where i can go to get one..... Take the bulb out of the dash.... if it hadnt have lit up you would have been none the wiser Quote Link to comment Share on other sites More sharing options...
live2themaxuk Posted November 6, 2006 Share Posted November 6, 2006 all i can say is, dont you EVERY start up a garage. . . . . use http://www.autopartstrader.co.uk parts request well im open to suggestions if you know where i can go to get one..... Take the bulb out of the dash.... if it hadnt have lit up you would have been none the wiser Quote Link to comment Share on other sites More sharing options...
Sarnie Posted November 6, 2006 Share Posted November 6, 2006 took car to the stealers today and they did a diagnostic check on it.... they sed its the seatbelt tensioner in the drivers seat and i need a new one .............. £404.............. jeeeeezzzz....... OWWWWWWW Quote Link to comment Share on other sites More sharing options...
H5 Posted November 7, 2006 Share Posted November 7, 2006 Also try www.partsgateway.co.uk Quote Link to comment Share on other sites More sharing options...
Liam's Z Posted November 7, 2006 Share Posted November 7, 2006 took car to the stealers today and they did a diagnostic check on it.... they sed its the seatbelt tensioner in the drivers seat and i need a new one .............. £404.............. jeeeeezzzz....... OWWWWWWW Try a different stealer mate.... I know this may sound unbelievable but it may be cheaper somewhere else Quote Link to comment Share on other sites More sharing options...
stuey Posted November 7, 2006 Author Share Posted November 7, 2006 well............ things are looking up..... i had a little fumble around under the drivers seat and went through the reset process and the dash light has been off now for 2 days...... Quote Link to comment Share on other sites More sharing options...
M13KYF Posted November 7, 2006 Share Posted November 7, 2006 cant beat a good fumble Quote Link to comment Share on other sites More sharing options...
