Window drop/height....
slimjim
Can you raise it any more by holding the up switch? If not I beleive that is it at highest it can go. You can reset where it sits I think, but if it doesnt go any higher manually with the switch then this wont make a difference as its already set to max. The only other issue then is if the window is square in the runners, and I dont know how to adjust this, but I am sure you can.
Good point MintSauce... why didn't I think of that :D
Will have a look in a min.
Ta!
