Beau Posted February 23, 2011 Share Posted February 23, 2011 Hi Guys, need a bit of advice. I am planning on getting 15/20mm spacers for the front but the stud length on the hub is about 24mm which means that 4mm will be sticking out with 20mm spacers. The wheels that im planning on fitting on it has a flat back which means the the extra stud length of 4mm will protrude and get in the way. Option 1 is to cut them off, but I dont really want to do this. Option 2 is that I just put 25mm on the front which will cover it up but will the wheel stick out too much? Option 3 is to buy a pcd adapter from 5x114 to 5x112 as the wheels are multi-fit and the protrusion on the studs will go into the 5x114 holes and the actual wheels will bolt onto the 5x112 option. Im not 100% sure this method will work though, just a theory. Any help much appreciated! Beau Quote Link to comment Share on other sites More sharing options...
M13KYF Posted February 23, 2011 Share Posted February 23, 2011 which type of spacers are you getting. There are a few. with the eibach spacers system 6 are the easiest ones to fit which doesn't inlvolve removing the current stud form the hub. System 4 does. Quote Link to comment Share on other sites More sharing options...
Beau Posted February 23, 2011 Author Share Posted February 23, 2011 There are some hubcentric ones on ebay which bolt on to the original hub and then allows the wheel to bolt on to the spacer. I think this is the best/safest set-up.... What do you think? Thanks, Beau Quote Link to comment Share on other sites More sharing options...
Stew Posted February 23, 2011 Share Posted February 23, 2011 I'd personally speak to the traders on here that sell wheel spacers for some proper advice. Also, what size and offset are the wheels? Quote Link to comment Share on other sites More sharing options...
Beau Posted February 23, 2011 Author Share Posted February 23, 2011 The front and rear are 9.5j and the offset is 35. Beau Quote Link to comment Share on other sites More sharing options...
M13KYF Posted February 24, 2011 Share Posted February 24, 2011 speak to CS, Andy at Kudos or MWTech, these traders supply spacers Quote Link to comment Share on other sites More sharing options...
Beau Posted February 24, 2011 Author Share Posted February 24, 2011 Thanks everyone. Been doing some research and I am now planning on buying longer wheel studs. Anyone else done this? Beau Quote Link to comment Share on other sites More sharing options...
UNABASHED Posted February 24, 2011 Share Posted February 24, 2011 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 24, 2011 Share Posted February 24, 2011 I don't know why you bother. Lost cause I am afraid Quote Link to comment Share on other sites More sharing options...
Neilp Posted February 24, 2011 Share Posted February 24, 2011 I don't know why you bother. Lost cause I am afraid Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted February 24, 2011 Share Posted February 24, 2011 Thanks everyone. Been doing some research and I am now planning on buying longer wheel studs. Anyone else done this? Beau Yes someone did try this method, but unfortunately the wheels fell off his car and he's now unable to give you advice due to the fact that he's in plaster from head to foot and currently recovering from his injuries in Sheffield Hallam hospital Good luck with your plan though Quote Link to comment Share on other sites More sharing options...
Beau Posted February 26, 2011 Author Share Posted February 26, 2011 Thanks for the confidence guys But Im sure this method will work, I just need to make sure the spacers have the correct lip. Quote Link to comment Share on other sites More sharing options...
CMR Posted February 26, 2011 Share Posted February 26, 2011 Why not just get the spacers like many have suggested which retain the standard bolts and basically are a piece of cake to fit Quote Link to comment Share on other sites More sharing options...
Chilli Red Posted February 26, 2011 Share Posted February 26, 2011 I think maybe he thought they we too expensive Quote Link to comment Share on other sites More sharing options...
Beau Posted February 26, 2011 Author Share Posted February 26, 2011 well, too expensive for what they are, and i was after 15mm spacers for the front but then that leaves some of the stud showing and the wheels I have bought are flat on the inside so that means I will need to cut the extra off, which I dont want to do. So I thought I would try this method! Quote Link to comment Share on other sites More sharing options...
UNABASHED Posted February 26, 2011 Share Posted February 26, 2011 I'd just buy the spacers that work properly first time, there has been loads for sale on here cheap as chips (including mine) Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 26, 2011 Share Posted February 26, 2011 This guy appears to be a retard so go easy on him. RIP Quote Link to comment Share on other sites More sharing options...
Stew Posted February 26, 2011 Share Posted February 26, 2011 RIP Retarded Internet Person. Quote Link to comment Share on other sites More sharing options...
