yankeesiter Posted February 22, 2011 Share Posted February 22, 2011 Got some new Iridiums from Zmanalex. Is 16mm the correct socket size? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 22, 2011 Share Posted February 22, 2011 5/8" is what you require. Quote Link to comment Share on other sites More sharing options...
terribleone Posted February 22, 2011 Share Posted February 22, 2011 Get a proper plug socket...they have a little rubber grommet in the end which grips the plug until it's tightened in place. I had loads kicking about from all the cheap tool sets I used to get through. Quote Link to comment Share on other sites More sharing options...
yankeesiter Posted February 22, 2011 Author Share Posted February 22, 2011 I was changing my spark plugs this afternoon with one of those sockets with a rubber insert to grip the plugs. After tighting up the 3rd plug I pulled the the socket out but the rubber insert stuck on the plug deep inside the cylinder head.Now I can't get a socket back on to remove the plug and I can't fit the coil pack thingy on! Does anybody have any ideas on how to remove the rubber?? Have decided to go for a magnetic one when I can, after reading this. Quote Link to comment Share on other sites More sharing options...
elfman Posted February 22, 2011 Share Posted February 22, 2011 I was changing my spark plugs this afternoon with one of those sockets with a rubber insert to grip the plugs. After tighting up the 3rd plug I pulled the the socket out but the rubber insert stuck on the plug deep inside the cylinder head.Now I can't get a socket back on to remove the plug and I can't fit the coil pack thingy on! Does anybody have any ideas on how to remove the rubber?? Have decided to go for a magnetic one when I can, after reading this. i had that problem with my mr2 when i changed the plugs, was a bugger to get back off!! Quote Link to comment Share on other sites More sharing options...
Beavis Posted February 22, 2011 Share Posted February 22, 2011 You could try a lenth of wire (coat hangar) with a hook at the bottom to try and get it off. I spray a bit of silicon on my rubber to help it not getting stuck Quote Link to comment Share on other sites More sharing options...
