Husky Posted February 21, 2011 Share Posted February 21, 2011 http://www.dumbfruits.com/2010/03/sql-i ... limit.html this just made my morning Quote Link to comment Share on other sites More sharing options...
UNABASHED Posted February 21, 2011 Share Posted February 21, 2011 brilliant Quote Link to comment Share on other sites More sharing options...
Husky Posted February 21, 2011 Author Share Posted February 21, 2011 apparently managed to change a sign http://bullshit.tumblr.com/post/3208223 ... -injection Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted February 21, 2011 Share Posted February 21, 2011 and what is the benefit of this? not taking the pi$$; i just don't understand what he is trying to attempt Quote Link to comment Share on other sites More sharing options...
Chris`I Posted February 21, 2011 Share Posted February 21, 2011 Whilst I would love this to work, it would take some truely retarted programmer not to check license plate formats before doing the required database lookup. Wouldnt be the first time a retarded programmer got the job though! Quote Link to comment Share on other sites More sharing options...
Toon Chris Posted February 21, 2011 Share Posted February 21, 2011 http://www.dumbfruits.com/2010/03/sql-injection-against-speed-limit.html this just made my morning Excellent, how brilliant if it works Quote Link to comment Share on other sites More sharing options...
Husky Posted February 21, 2011 Author Share Posted February 21, 2011 Whilst I would love this to work, it would take some truely retarted programmer not to check license plate formats before doing the required database lookup. Wouldnt be the first time a retarded programmer got the job though! this is what i thought, I think it's fairly possible a r'tard programmed it and so it works and what is the benefit of this? not taking the pi$$; i just don't understand what he is trying to attempt if you think about it the scanner reads the number plate and converts it to text, it then inserts the text into a database, so the theory is that if you insert code into the database via the scanner instead of a reg plate it will execute the code. The codes purpose would be to wipe the database. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted February 21, 2011 Share Posted February 21, 2011 and what is the benefit of this? not taking the pi$$; i just don't understand what he is trying to attempt if you think about it the scanner reads the number plate and converts it to text, it then inserts the text into a database, so the theory is that if you insert code into the database via the scanner instead of a reg plate it will execute the code. The codes purpose would be to wipe the database. Withouth knowing the underlying table structure, the best you could achieve is for the numberplate not to be recognised so that you dont get billed. In reailty, it'd flag up as an error and a human operator will do it and then they'd come after you for fecking with their systems Quote Link to comment Share on other sites More sharing options...
narcotix Posted February 21, 2011 Share Posted February 21, 2011 Hahahah ... That's Brilliant! Quote Link to comment Share on other sites More sharing options...
geoff-r Posted February 21, 2011 Share Posted February 21, 2011 Brilliant! Quote Link to comment Share on other sites More sharing options...
cesc Posted February 21, 2011 Share Posted February 21, 2011 Reminds me of this: Quote Link to comment Share on other sites More sharing options...
Husky Posted February 21, 2011 Author Share Posted February 21, 2011 Reminds me of this: Quote Link to comment Share on other sites More sharing options...
Chris`I Posted February 21, 2011 Share Posted February 21, 2011 Reminds me of this: Its a classic Quote Link to comment Share on other sites More sharing options...
Stew Posted February 21, 2011 Share Posted February 21, 2011 AAAAAARRRRRRRRRRRGGGGGGGGGGGGGGGHHHHHHHHHHHHHHHHH Too much Geek! Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted February 21, 2011 Share Posted February 21, 2011 How would that even work The camera is looking for records within a table, not for an sql statement to execute Quote Link to comment Share on other sites More sharing options...
Chris`I Posted February 21, 2011 Share Posted February 21, 2011 The camera is looking for records within a table, not for an sql statement to execute Its perfectly possible if you know how SQL works and if the types arent strongly typed (ie not format checked in this case). Wikipedia is your friend - http://en.wikipedia.org/wiki/SQL_injection Heres their example reworked for this - Stew look away now! Usual select to look up car details statement := "SELECT * FROM `carinfo` WHERE `id` = " + a_numberplate + ";" a_numberplate (not strongly typed so this could be on the car and read) could be this rather than a numberplate 1;DROP TABLE `car_owners` so the code ran is ... SELECT * FROM `carinfo` WHERE `id`=1;DROP TABLE `car_owners`; Now you've gone and deleted all car owners in the system Now to do this you need to have a good working knowledge of their database structure to start farting about with it. You also have to assume some retard hasnt checked that the numberplate read is a recognised format! Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted February 21, 2011 Share Posted February 21, 2011 Thanks Chris I do know how SQL works after studying Database Administration at University and years of using Oracle... It is also perfectly possible for someone to have spent a minute or two putting even a rudimentary amount of validation into the system Quote Link to comment Share on other sites More sharing options...
Husky Posted February 22, 2011 Author Share Posted February 22, 2011 Thanks Chris I do know how SQL works after studying Database Administration at University and years of using Oracle... It is also perfectly possible for someone to have spent a minute or two putting even a rudimentary amount of validation into the system Thats you told Quote Link to comment Share on other sites More sharing options...
Chris`I Posted February 22, 2011 Share Posted February 22, 2011 Thanks Chris I do know how SQL works after studying Database Administration at University and years of using Oracle... It is also perfectly possible for someone to have spent a minute or two putting even a rudimentary amount of validation into the system No offence but it didnt sound like it the way you worded the comment, the whole point of SQL injection (as you know) is to insert SQL where SQL shouldnt be And we had already said that it would only work if there was a numpty coding it with no validation checking. Quote Link to comment Share on other sites More sharing options...
