Lilliput 7" **NOW SOLD**
SunGodRA
I bought 2x of these for CarPC install, but have decided to only use 1. Brand new and still in box, cost me £165, will take £120 delivered.
ebay link where I purchased: http://cgi.ebay.co.uk/Lilliput-7-669GL- ... 932wt_1139
Features:
7†TFT LCD Color Car Monitor with adjustable LED backlighting
High Resolution, Wide Viewing Angle, with native 16:9 screen ratio.
Menu Language Options: Chinese/English
Support four kinds of input for multi usage.
HDMI input: Supports MAX 1080p ( 1920*1080p ) and 1080i( 1920*1080i),Compatible with Devices with HDMI or mini HDMI
output such as Canon 5D mark II,Canon 7D,Nikon D300S and D3S and so on
DVI input: Supports MAX 1920*1080, via DVI to HDMI cable connected with HDMI
VGA input: Compatible with PC
RCA (AV) input: Auxiliary RCA Audio and 2x RCA Video Inputs for Rear View Camera and Gaming Systems
Color system: PAL-4.43, NTSC-3.58
HDMI input Supports MAX 1080p ( 1920*1080p ) and 1080i( 1920*1080i),Compatible with Devices with HDMI or mini HDMI output such as Canon 5D mark II,Canon 7D,Nikon D300S and D3S and so on
DVI input Supports MAX 1920*1080, via DVI to HDMI cable connected with HDMI
VGA input Compatible with PC
AV input Compatible with DVD/VCD Player/Security System/Navigation system/Rear view camera
LED Backlight yes
Auto-trigger NO (Default). It means 669GL-70NP/C auto-switches to rearview camera display if your car is on reverse.If you need to use 669GL-70NP/C in your car,and connect it to a car rearview camera, Please choose "Auto-trigger", $8 more .
Display Panel TFT LCD 7"
Aspect Ratio 16:9
Display Ratio 16:9 or 4:3 adjustable
OSD Languages(2 available) English, Chinese
Resolution 800×480 (up to 1920×1080)
Brightness 450cd/㎡
Contrast Ratio 500:1
Signal Input HDMI, DVI,AV1, AV2, PC (VGA)
Viewing Angle 140°/ 120°(H/V)
Color System PAL-4.43, NTSC-3.58
Input Voltage DC 12V
Audio Output ≤1W
Power Consumption ≤8W
Size (LWD)(mm) 185.5×122×32.5mm
Weight 0.40kg(only monitor)
Accessories
VGA 9-pin cable 1 piece
Bracket 1 piece
Touch pen 1 piece
Drive disk 1 piece
Remote control 1 piece
14PIN SKS 1 piece
Home DC adapter 1 piece
Car lighter Adapter(DC 12V)
1 piece
Manual 1 copy
HDMI signal cable(HDMI to HDMI) 1 piece
DVI line 24+5/DVI-D cable 1 piece
