Anyone got or had takeda or weapon r cai kits?
Dano190485
Hi, The CAi make the best noise but we find these are bad for heat soak as the air filters pick air up from under the bonnet where as the stock airboxes pick up cold air from behind the bumper.
I personally would go for HKS or any type of panel filter in the stock air box's.
But like any 350Z to get the proper gains from the bolt on the car will need remapping.
Agreed.
Here is my solution!
http://www.370z-uk.net/forum/viewtopic.php?f=20&t=42577&start=0&sid=970a6af1003a8c3b3c63652631d86527
Admittedly it doesn't do much to protect against the heat soak around the cone filters, but at least with a bit more cold air getting sucked in it helps to mitigate the effects.
:D
