sparky370z Posted February 11, 2011 Share Posted February 11, 2011 a quick one, After my recent install im now not sure if my sub is on. Not sure what i have done. Im sure i have connected everything right. I have a alpine system. Got the correct loom (i think). Thanks in advance. Sparky Quote Link to comment Share on other sites More sharing options...
racinggreen Posted February 11, 2011 Share Posted February 11, 2011 Does the Alpine system have an on/off function for the sub? Quote Link to comment Share on other sites More sharing options...
sparky370z Posted February 11, 2011 Author Share Posted February 11, 2011 Does the Alpine system have an on/off function for the sub? Yes i belive it does. But im sure thats turned on. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted February 12, 2011 Share Posted February 12, 2011 Can you describe your system? Is it a full aftermarket or are bits running via OEM Nissan parts? Quote Link to comment Share on other sites More sharing options...
sparky370z Posted February 12, 2011 Author Share Posted February 12, 2011 My system is just a aftermarket HU, using all the exsiting bose speakers, amps and sub. Its quite loud but ekona gave me a unit that increases the volume. Only prob is i dont know where it goes. I assume it goes between the back speakers and the HU. Quote Link to comment Share on other sites More sharing options...
srobrien Posted February 12, 2011 Share Posted February 12, 2011 My system is just a aftermarket HU, using all the exsiting bose speakers, amps and sub. Its quite loud but ekona gave me a unit that increases the volume. Only prob is i dont know where it goes. I assume it goes between the back speakers and the HU. I had one of these on my pioneer. I put it on the rears as the headunit function "beeps" were channelled to the fronts which meant they were super loud every time it went off. I know the general consensus is the rear speakers are not that great so I would try them on both sides to see which works best. R Quote Link to comment Share on other sites More sharing options...
Chris`I Posted February 12, 2011 Share Posted February 12, 2011 The Bose stuff is all fed off speaker level outputs, so make sure that any dedicated sub output is turned off, that way it will send all frequencies through the speakers, rather than redirecting the low level sound to the sub. Not sure what the unit is Dan gave you - if its a PAC-ROEM then it goes on the back of the head unit and then clips into the existing wiring that you unplugged from the headunit. The PAC-ROEM also allows you to change the levels per speaker, so have a fiddle and you can adjust front/rear to be right. Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted February 12, 2011 Share Posted February 12, 2011 Have a fiddle with the settings on the HU, as mentioned above on the Pioneer units you can have sub+rear or just rear with no sub... might be the same on yours I know it sounds silly but have you put your hand on the front of the sub grille it is fairly easy to tell if it is on or not Quote Link to comment Share on other sites More sharing options...
sparky370z Posted February 12, 2011 Author Share Posted February 12, 2011 No, its just a unit with 2 phono, in and 2 phono out. And a power wire. I think. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted February 12, 2011 Share Posted February 12, 2011 Not a PAC-ROEM then. So atm how do you have the headunit feeding into the Nissan loom? Did you buy a loom converter? Normally if you feed an aftermarket HU into the standard BOSE loom, it sounds very quiet, the PAC-ROEM increases the speaker outputs to what the amps expect. Quote Link to comment Share on other sites More sharing options...
srobrien Posted February 12, 2011 Share Posted February 12, 2011 No, its just a unit with 2 phono, in and 2 phono out. And a power wire. I think. Is it this badboy? http://www.sextonsdirect.co.uk/autolead ... html?cat=0 Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted February 12, 2011 Share Posted February 12, 2011 No, its just a unit with 2 phono, in and 2 phono out. And a power wire. I think. Is it this badboy? http://www.sextonsdirect.co.uk/autolead ... html?cat=0 i had 2 of those fitted to mine when I was using the Bose speakers and Amp, 1 for fronts and 1 for rears... the 'Beep' wasn't a problem as I hacked it to silent It worked fine with the Sub so not sure what your problem is, sounds like it is HU related to me... Quote Link to comment Share on other sites More sharing options...
sparky370z Posted February 12, 2011 Author Share Posted February 12, 2011 Yup thats the kiddy. Perhaps i'll get another one and put that on the front then. I really cant tell if the sub is going tho. Perhaps im just being special. The sound level is ok, but just could be better if a bit louder. Im not really one for having my ears bleed but sometimes louder is better. Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted February 12, 2011 Share Posted February 12, 2011 Yup thats the kiddy. Perhaps i'll get another one and put that on the front then. I really cant tell if the sub is going tho. Perhaps im just being special. The sound level is ok, but just could be better if a bit louder. Im not really one for having my ears bleed but sometimes louder is better. Come down to Brighton tomorrow and you I will have a look I mean listen Quote Link to comment Share on other sites More sharing options...
sparky370z Posted February 12, 2011 Author Share Posted February 12, 2011 Yup thats the kiddy. Perhaps i'll get another one and put that on the front then. I really cant tell if the sub is going tho. Perhaps im just being special. The sound level is ok, but just could be better if a bit louder. Im not really one for having my ears bleed but sometimes louder is better. Come down to Brighton tomorrow and you I will have a look I mean listen I really dont think that im gonna be able to make it now. I have to save money for the purchase of my house. We have just been told that we need to pay out roughly 1k by the end of the month. Oh dear!! So putting 60 quid of fuel at least is low down the list of priorities. Its a real pain as i was looking forward to going. I like brighton and the drive is nice. We will see you at the next one for sure! Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted February 12, 2011 Share Posted February 12, 2011 Yup thats the kiddy. Perhaps i'll get another one and put that on the front then. I really cant tell if the sub is going tho. Perhaps im just being special. The sound level is ok, but just could be better if a bit louder. Im not really one for having my ears bleed but sometimes louder is better. Come down to Brighton tomorrow and you I will have a look I mean listen I really dont think that im gonna be able to make it now. I have to save money for the purchase of my house. We have just been told that we need to pay out roughly 1k by the end of the month. Oh dear!! So putting 60 quid of fuel at least is low down the list of priorities. Its a real pain as i was looking forward to going. I like brighton and the drive is nice. We will see you at the next one for sure! Bummer, but completely understand the priority there! Quote Link to comment Share on other sites More sharing options...
un1eash Posted February 12, 2011 Share Posted February 12, 2011 If your using an alpine headunit and the phono outputs to feed the bose amps the best thing to do first is turn off all filters and cross over freq. Sounds like the headunit isn't sending out any low freq over the front and rear channels. What headunit is it? Is it imprint ready? Quote Link to comment Share on other sites More sharing options...
sparky370z Posted February 12, 2011 Author Share Posted February 12, 2011 If your using an alpine headunit and the phono outputs to feed the bose amps the best thing to do first is turn off all filters and cross over freq. Sounds like the headunit isn't sending out any low freq over the front and rear channels. What headunit is it? Is it imprint ready? The unit is an iva 202r. I think. Not sure about the imprint. I'll try what you said. Quote Link to comment Share on other sites More sharing options...
