Ebized Posted February 6, 2011 Share Posted February 6, 2011 For the untrained word processors amongst us. Is it me, or do you make the same old mistakes and you wonder why the design is like it is? The one that really gets me is why can't the Caps Lock button have the light in it or alongside rather than at the other end of the keyboard? Times I have to edit stuff, when I look up at the screen and see a line full of uppercase Quote Link to comment Share on other sites More sharing options...
martinmac Posted February 6, 2011 Share Posted February 6, 2011 I do the same Colin. I blame it on the varifoculs, when I am typing I need to look at the letters and this means the upper part of the glasses are aimed at the screen. Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted February 6, 2011 Share Posted February 6, 2011 For the untrained word processors amongst us. Is it me, or do you make the same old mistakes and you wonder why the design is like it is? The one that really gets me is why can't the Caps Lock button have the light in it or alongside rather than at the other end of the keyboard? Times I have to edit stuff, when I look up at the screen and see a line full of uppercase Colin, you have the answer to your own problem in the last sentence.... don't look at the keyboard, look at the screen while you type Keep your little pinkies on 'A' and 'L' and you will know where every key is Quote Link to comment Share on other sites More sharing options...
Ebized Posted February 6, 2011 Author Share Posted February 6, 2011 For the untrained word processors amongst us. Is it me, or do you make the same old mistakes and you wonder why the design is like it is? The one that really gets me is why can't the Caps Lock button have the light in it or alongside rather than at the other end of the keyboard? Times I have to edit stuff, when I look up at the screen and see a line full of uppercase Colin, you have the answer to your own problem in the last sentence.... don't look at the keyboard, look at the screen while you type Keep your little pinkies on 'A' and 'L' and you will know where every key is Yeah, but I need to use letters other than A and L and I only have two pinkies that work Quote Link to comment Share on other sites More sharing options...
Wasso Posted February 6, 2011 Share Posted February 6, 2011 Instead of shift lock, use shift on it's own, that way once you let go you know you're no longer in CAPITALS! Opps held my finger for too long. Quote Link to comment Share on other sites More sharing options...
HaydnH Posted February 6, 2011 Share Posted February 6, 2011 Keep your little pinkies on 'A' and 'L' and you will know where every key is The furthest right home key (i.e: where your right pinkie should be) is ; not L. Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted February 6, 2011 Share Posted February 6, 2011 Keep your little pinkies on 'A' and 'L' and you will know where every key is The furthest right home key (i.e: where your right pinkie should be) is ; not L. Each to their own, I like to be different Quote Link to comment Share on other sites More sharing options...
Lexx Posted February 6, 2011 Share Posted February 6, 2011 Some keyboards do have a light in the caps lock button... Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted February 6, 2011 Share Posted February 6, 2011 Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted February 6, 2011 Share Posted February 6, 2011 Get a gaming keyboard and setup a layout that disables the Caps Lock Currently got a Microsoft Gaming keyboard that let's me switch between three layouts. Quote Link to comment Share on other sites More sharing options...
shieldsie Posted February 6, 2011 Share Posted February 6, 2011 Tip of the week for you If you type with caps on accidentally, and get all capitals, then highlight the words you want to change case and push shift and F3 together. The first time F3 is pushed it will change capitals to small case, if you push F3 again it will give you capitals at the word beginning, and again it will give you all capitals Quote Link to comment Share on other sites More sharing options...
HaydnH Posted February 6, 2011 Share Posted February 6, 2011 Tip of the week for you If you type with caps on accidentally, and get all capitals, then highlight the words you want to change case and push shift and F3 together. The first time F3 is pushed it will change capitals to small case, if you push F3 again it will give you capitals at the word beginning, and again it will give you all capitals I guess that's in MS Word? Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted February 6, 2011 Share Posted February 6, 2011 Tip of the week for you If you type with caps on accidentally, and get all capitals, then highlight the words you want to change case and push shift and F3 together. The first time F3 is pushed it will change capitals to small case, if you push F3 again it will give you capitals at the word beginning, and again it will give you all capitals If you are on Windows and in Word Quote Link to comment Share on other sites More sharing options...
shieldsie Posted February 6, 2011 Share Posted February 6, 2011 Yes, in word docs. It doesnt apply with emails etc, but is very useful for those working in word. Quote Link to comment Share on other sites More sharing options...
Ebized Posted February 7, 2011 Author Share Posted February 7, 2011 Tip of the week for you If you type with caps on accidentally, and get all capitals, then highlight the words you want to change case and push shift and F3 together. The first time F3 is pushed it will change capitals to small case, if you push F3 again it will give you capitals at the word beginning, and again it will give you all capitals Thanks shieldsie - no doubt will become two of my used keys .....still hope there is a (non-gaming) keyboard out there with light next or on the caps lock that might save the corrections Quote Link to comment Share on other sites More sharing options...
UNABASHED Posted February 7, 2011 Share Posted February 7, 2011 mine does Quote Link to comment Share on other sites More sharing options...
ChrisS Posted February 7, 2011 Share Posted February 7, 2011 Caps Lock...............beep helps. (but can't remember how to tutn it on and off...... ) Quote Link to comment Share on other sites More sharing options...
