CharlesB Posted February 3, 2011 Share Posted February 3, 2011 Hi I looking for an uptodate disk for my 350z Sat Nav..... Any ideas anyone?? Quote Link to comment Share on other sites More sharing options...
Wasso Posted February 3, 2011 Share Posted February 3, 2011 Nissan charge something like £400 for the disk, it's really not worth the hassle. Unless there is some way of copying a recent disk, but then again I think the updated disk don't work on the older Satnav's Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted February 3, 2011 Share Posted February 3, 2011 Hi I looking for an uptodate disk for my 350z Sat Nav..... Any ideas anyone?? http://www.satnav-updates.com/index.php?cat=2011_NISSAN_X7___X6_SAT_NAV_DISCS&ActinicSID=c480b1913648dfb12f43eab0e38b6146 Quote Link to comment Share on other sites More sharing options...
CharlesB Posted February 3, 2011 Author Share Posted February 3, 2011 Thanks spursmadDave.... I'll give him a call Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted February 3, 2011 Share Posted February 3, 2011 Thanks spursmadDave.... I'll give him a call May be cheaper options I don't have the factory SatNav... Quote Link to comment Share on other sites More sharing options...
HaydnH Posted February 4, 2011 Share Posted February 4, 2011 On a side note: I've been tempted to copy mine for a backup, any idea if this would work or is there some form of copy protection on it? Quote Link to comment Share on other sites More sharing options...
Wasso Posted February 4, 2011 Share Posted February 4, 2011 You could always try copying and testing in the car to see what happens? Quote Link to comment Share on other sites More sharing options...
JetSet Posted February 4, 2011 Share Posted February 4, 2011 On a side note: I've been tempted to copy mine for a backup, any idea if this would work or is there some form of copy protection on it? Caroline's 2008 Sat Nav disk is a double sided DVD, ordinary DVD recorders won't copy it because it contains 9GB of data on it. Special equipment required unfortunately. No idea if it's copy protected but there are ways around that Pete Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted February 4, 2011 Share Posted February 4, 2011 On a side note: I've been tempted to copy mine for a backup, any idea if this would work or is there some form of copy protection on it? Caroline's 2008 Sat Nav disk is a double sided DVD, ordinary DVD recorders won't copy it because it contains 9GB of data on it. Special equipment required unfortunately. No idea if it's copy protected but there are ways around that Pete You don't need any special equipment, most drives now copy Dual Layer disks which is what you need, a double sided disk would need turning over anyway so you could copy each side onto a normal dvd There are ways round anything pretty much anything unless you need to get an 'unlock' code from the manufacturer... Quote Link to comment Share on other sites More sharing options...
chriswatson99 Posted February 9, 2011 Share Posted February 9, 2011 Thanks for the recommendation SpursMadDave, replaced my 06 cd and looks fine so far Quote Link to comment Share on other sites More sharing options...
rob d Posted June 26, 2011 Share Posted June 26, 2011 Did it make much difference ? Do you still have the disc ? i have an 06 roadster and it would be nice to update before I do my run around europe in a week or so.. Quote Link to comment Share on other sites More sharing options...
ersen.o Posted June 26, 2011 Share Posted June 26, 2011 they aint double sided, theyre dual layer lol and u cant split it to 2 dvd Quote Link to comment Share on other sites More sharing options...
Rentech Posted July 6, 2011 Share Posted July 6, 2011 On a side note: I've been tempted to copy mine for a backup, any idea if this would work or is there some form of copy protection on it? Although the Zed has now gone I can confirm that you can back them up. My original dvd was badly scratched when I got the car, though it still worked perfectly. Just in case it packed up I made a back up. I think it's fairly fussy about the type of burner and disk used. Took two attempts to get a working copy. I used a verbatim disc and a Lite-on burner on the slowest speed with Alcohol 120. If you have to buy the kit from scratch it may well turn out cheaper to buy from the link in this discussion Quote Link to comment Share on other sites More sharing options...
Viper Posted July 11, 2011 Share Posted July 11, 2011 ive a 2010-11 on a dual layer DVD which came with the car though it only seems to be UK not Europe, will try and copy it Quote Link to comment Share on other sites More sharing options...
Viper Posted July 21, 2011 Share Posted July 21, 2011 had to buy a new DVD writer as my old one wouldnt burn dual layer DVD's, copied it tonight, though i havent tried out on the road will see tomorrow if it really worked... Quote Link to comment Share on other sites More sharing options...
ersen.o Posted July 21, 2011 Share Posted July 21, 2011 it worked for me, im running the 2011 disc but i had to buy verbatim dual layer discs, normal cheapo dics didnt work Quote Link to comment Share on other sites More sharing options...
Chris`I Posted July 21, 2011 Share Posted July 21, 2011 but i had to buy verbatim dual layer discs, normal cheapo dics didnt work Tends to be the same when *ahem* backing up *ahem* games discs too Quote Link to comment Share on other sites More sharing options...
