No water jet from passenger side wiper arm
RisingPower
So, I read a few other similar threads and found the check valve in the brake fluid area, but that's fine and anyway it seems to be for the driver side arm.
Now, looking at the service manual, it mentions two check valves, one wider than the other, if so, any ideas where this is?
Or any other ideas at which point the tube could be blocked (not the arm, tried that with a pin)?
Cheers :thumbs:
I once experienced a blockage just prior to the jets (not on a zed), which required taking the hose from the nozzle off and clearing the blockage. It had me baffled for weeks as to why there was no water coming through.
Just a thought?
