Climate Control
Dicky
Two options:
turn air con off but outside air on + cool air and you are good.
or
turn air con on + cool air.
My normal setting at the moment is AUTO, OUTSIDE AIR, 20DEG, No aircon.
Edit: took me a while, being a bit thick, to realise that OUTSIDE AIR on its own often did the same job as AIRCON. :headhurt:
It's just where the air initially pushed through is warmer than the screen and the air con hasn't started dehumidifying. All systems do it at this time of year when the temp drops at night and the engine retains some heat.
BTW, also get the drainage tube double checked that it's not blocked. Could be the start of a longer term problem where you'll get wet feet!! ;)
I would've thought so. Only reason I know is my Volvo tube got blocked and the liquid wasn't draining away, until it emptied in the car!!
Speak to a dealer to check where it is and then it should be a simple check to make sure when the system has been on and it needs to discharge the condensed moisture it goes outside the car.
