Crashbar wall thickness?
SteveW
Hey hopefully someone knows the answer to this so here goes.
Does anyone know the wall thickness of the crashbar? I'm
Trying to decide whether I should drill and tap one side and mount my oil
Cooler like that or drill right through and then use nuts and long bolts.
Cheers
Steve
Here's a thread Rich posted, maybe he remembers? viewtopic.php?f=35&t=34687&start=0
Cheers
Steve
You'll see when you get the bumper off, but the profile of the beam is the same as how a calculator displays a figure 8. There's another bit of metal in the middle to add stiffness I assume. I only attached to the bottom and used a few washers to spread the load and it's been fine for a few 1000 miles so far.
Hi Mate,
I've mounted my cooler to the back of the crashbar.
I drilled right through the lower portion of the '8' then used some big washers looks good and nicely out of the way, just gotta fit the take off plate now.
Got a bit late last night and need the car for work so need some time when I can make sure its not leaking!
Cheers
Steve
