Is changing the Z gear knob a simple un-screw?
In essence Chris' idea is the same as the guide.
There is a drop of threadlock on the knob, thus making it rather tight and hard to unscrew, once you managed the initial twist-off, the rest should be easy.
You deffo need to hold the gear shft stable, because if you don't you might end up damaging the syncro-mesh (read as "cause expensive fix")
The guide is just to look at, it really isn't that much to worry about :lol:
Just hold the shaft nice and tight, give your knob a good hard tug and you should be able to screw it off quite easily :thumbs:
Worth the effort too B)
It's really hard to explain what needs doing without sounding like a sex manual
I have no idea what you mean, please explain :snack:
Ah Dave, that is exactly the same reason I changed my knob, for a lovely KTA solid stainless
In my case I found a few turns in opposite directions loosened it off, but it was still quite stiff. The now came off in one piece and I even sold it on eBay for £50 ;)
Ah Dave, that si exactly the same reason I changed my knob, for a lovely KTA solid stainless
Chris have you photoshopped your knob as it looks HUGE :lol:
