BladesGrant Posted January 27, 2011 Share Posted January 27, 2011 My boiler is kind of playing funny buggers. But I am not sure its the actual boiler. Its a condensing boiler and it keeps failing to fire up, now I thought it was because the pipes were frozen. But its been working fine and the thermostat circle that you turn to alter the temp got knocked off. I don't know how to make sure its back on in the right place, plus since this has happened the boiler hasn't fired up properly or maintained a constant temp. Anyone with any ideas before I get someone out?? Can the thermostat not being on proper affect the boiler firing up?? Quote Link to comment Share on other sites More sharing options...
glrnet Posted January 27, 2011 Share Posted January 27, 2011 As I understand the thermostat is critical to the boiler firing up, sounds like the thermostat got damaged when the dial got knocked off Quote Link to comment Share on other sites More sharing options...
BladesGrant Posted January 27, 2011 Author Share Posted January 27, 2011 It wasn't the entire thermostat just the centre circle, it still clicks when you turn it which then it turn starts the boil to fire up. Its just the boiler doesn't always fire up. Looking for an easy way to re-align the circle back into the original position as I can't tell how it should go on. Quote Link to comment Share on other sites More sharing options...
