Alingment Issues
Brianpiper
Hi there, has anyone experienced the same problem where the front tires scrub. I have 12,000 klm on my 2007 350Z Roadster and have had to replace all four tires. The interesting thing is the alignment was not in my mind been out by much, although I understand the 350Z is critical to be spot on.
Wear on the outer edges of the tires were worn approx 2 mm more than the inner surface on all four? To me this is appears to be an issue of camber and indicates the tires are slightly positive in camber???
I have had discussions with Nissan to no real avail
look forward to some comments
Brian
Yup, looks like geometry is way off. I suspect both camber and toe :surrender:
You do not need nissan unless you just had the car and its still under warranty from them and this is covered. Go to any reputed alignment place in your area and get a full 4 wheel geo back to factory settings.
I presume your car is standard and not lowered ;) There is a post with hese settings somewhere here if not i can put them out FYI.
