Bazza1 Posted January 24, 2011 Share Posted January 24, 2011 Hi, the spacesaver on my car will not go over the Bembro brakes. The holes line up, I have been offered an 300zx space saver, will this fit? does anybody have one for sale otherwise. thanks Bazza Quote Link to comment Share on other sites More sharing options...
Goldcrest Four Posted January 24, 2011 Share Posted January 24, 2011 Forgive me if this is a silly question: but are you lining up the locating stud with the appropriate hole? The spacesaver will only fit 'one' way. Quote Link to comment Share on other sites More sharing options...
Lincolnbaggie Posted January 24, 2011 Share Posted January 24, 2011 Forgive me if this is a silly question: but are you lining up the locating stud with the appropriate hole? The spacesaver will only fit 'one' way. +1 You have to align the hole on the wheel with the locating stud on the hub. It should then fit. Quote Link to comment Share on other sites More sharing options...
mbs Posted January 24, 2011 Share Posted January 24, 2011 IIRC you have to put the space saver on the rear Quote Link to comment Share on other sites More sharing options...
Goldcrest Four Posted January 24, 2011 Share Posted January 24, 2011 Mine fits front and rear if located properly Quote Link to comment Share on other sites More sharing options...
Bazza1 Posted January 24, 2011 Author Share Posted January 24, 2011 My car has Bembro brakes, it looks as though the wheel will not cover the brakes, all the studs line up, are there 2 diffrent spacesavers? Quote Link to comment Share on other sites More sharing options...
Goldcrest Four Posted January 25, 2011 Share Posted January 25, 2011 The threaded studs will align in 5 rotational positions but the wheel will only only fit in one position; that on whch the unthreaded stud slides int the appropriate (additional) hole in the wheel. Unless you have a non-standard (incorrect) spacesaver of course. Quote Link to comment Share on other sites More sharing options...
Ekona Posted January 25, 2011 Share Posted January 25, 2011 IIRC you have to put the space saver on the rear Complete opposite, space saver always goes on the non-driven wheels. On the front if your car is RWD, on the rear if FWD. Quote Link to comment Share on other sites More sharing options...
JetSet Posted January 25, 2011 Share Posted January 25, 2011 IIRC you have to put the space saver on the rear Complete opposite, space saver always goes on the non-driven wheels. On the front if your car is RWD, on the rear if FWD. Didn't know that, so basically if you get a rear wheel puncture you're stuffed? I suppose you could remove a front wheel and put it on the back but surely the LSD would have a nervous breakdown running different rolling diameters on the same axle. I hadn't thought about this before but staggered wheels are a bit of a nightmare if you get a puncture Pete Quote Link to comment Share on other sites More sharing options...
