SteveW Posted January 22, 2011 Share Posted January 22, 2011 well I'm in the process of changing my rear discs, I have been suffering with loads of vibration from the back end no matter which disks I use. Well today I've been trying to fit my new ones and actually using a DTI and found no matter which bolt hole I put the disks on I cannot get the run out below 0.25mm on the left and 0.15mm on the right! Explains all my problems..... Any advice? The only way I can see to fix it is complete new hubs and wheel bearings or shim the disks so they run straight. Suppose the final option is to find the high points on the hub mounting face and file off but the studs make this very difficult. I've cleaned up the hub faces before trying the disks. Has anyone got any suggestions or am I buggared? Cheers Steve Quote Link to comment Share on other sites More sharing options...
Cragus Posted January 22, 2011 Share Posted January 22, 2011 Quote Link to comment Share on other sites More sharing options...
SteveW Posted January 22, 2011 Author Share Posted January 22, 2011 Oh yeah obviously there is the skimming option but don't wanna go down that road again been there many times before and it just gets expensive! Quote Link to comment Share on other sites More sharing options...
