Oil capacities
jimgallaher
Engine oil
- with filter change 4.9 litres
- without filter change 4.6 litres
- dry engine overhaul 5.5
Cooling system
- with resevoir tank 9.0 litres
-resevoir tank 0.8 litres
auto transmission fluid 10.3 litres
manual transmission gear oil 2.93 litres
power steering fluid 1 litre
differential gear oil 1.4 litres
does this answer most questions?
I'm about to buy oil for my P3 service MY2007 GT 350Z, can anyone tell me how much engine, gearbox and diff oil I need ? Also some recommendations as to brand etc would be appreciated. Also plugs , seems denso iridiums are highly thought of, but which ones do I need ?
Thanx
engine oil should be 5w30 according to service manual i liked royal purple oil but would also reccomend fuchs titan pro S but anything with an API certificate of mark **1 will do. :thumbs:
coolant i'd use nissans own coolant
transmission fluid 75w85 or 75w90
brake fluid a minimum of dot 3 i used millers or motul but any good brand is worth a punt
diff oil 80w90*5
