Snapon Posted January 14, 2011 Share Posted January 14, 2011 Hi all can any one tell me when u open the drivers door the window goes down a bit is this ment to do the same on passenger door as well THANKShttp://www.350z-uk.com/forum/post ... e=post&f=9# Quote Link to comment Share on other sites More sharing options...
UNABASHED Posted January 14, 2011 Share Posted January 14, 2011 same on both doors IIRC Quote Link to comment Share on other sites More sharing options...
SparksCW Posted January 14, 2011 Share Posted January 14, 2011 Yes passenger door should do same too. I believe if it doesn't it could be something with the window mechanism, someone with more experience will prob answer soon though. Quote Link to comment Share on other sites More sharing options...
varley16 Posted January 15, 2011 Share Posted January 15, 2011 on the cars ive worked on, if it loses it memory it wont drop. try reseting them, press and hold down on the window switch, when it reaches the bottom, hold it for 5 seconds, release, and then press down again, then go up, and when it reaches the top, hold for 5 seconds, release and then press up again. well thats the procedure on other cars ive worked on. should be pretty much the same. Quote Link to comment Share on other sites More sharing options...
martinmac Posted January 15, 2011 Share Posted January 15, 2011 There is a procedure for window reset in the guides section. Quote Link to comment Share on other sites More sharing options...
