Centre Cubby Motorised Panel - 68250-CD00A
chrisgunton
Thats not motorised tho..
Also there is aditional wiring that needs to be on the car for it to work....standard cars dont have this..im not even sure what is needed. I think it would be a nightmare to try and get a motorised cubby into a none motorised dash
anythings possible ;)
I don't know if it's meant to open automatically, or if the button needs to be pressed.
Does it need a 12v source or more than that?
There is a board ontop of the cubby which a ribbon cable plugs in....trust me go for the one that you linked to (that is non motorised) as all you need to do is push the button and the cubby will open..then you just manually pull it down
