Chan267 Posted January 13, 2011 Share Posted January 13, 2011 Hello I just got my plenum spacer from motordyne installed and my seibon carbon bonnet sits abit higher than usual. Has anyone had the same problem and how do people solve it? Has anyone removed the oem strut brace at the front and noticed a big difference? Any help or advice would be great Quote Link to comment Share on other sites More sharing options...
DoogyRev Posted January 13, 2011 Share Posted January 13, 2011 I think you need to put spacers on the Strut Brace so it clears with the plenum installed Quote Link to comment Share on other sites More sharing options...
Zugara Posted January 13, 2011 Share Posted January 13, 2011 You should have washers to go under the brace to raise it up a bit giving the clearance you need. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted January 13, 2011 Share Posted January 13, 2011 You should not run without the strut brace, if that is what you are asking. Also what size of spacer did you fit? Alex Quote Link to comment Share on other sites More sharing options...
Ian Posted January 13, 2011 Share Posted January 13, 2011 The bonnet sits higher? I had to cut a part of my seibon bonnet to fit over the stock & cusco braces when installed with a spacer Quote Link to comment Share on other sites More sharing options...
Chan267 Posted January 13, 2011 Author Share Posted January 13, 2011 I fitted a 5/16 motordyne spacer that I brought from abbey motorsport. There is washers fitted with the new screws supplied with this spacer. My problem is because the strut brace is sitting higher than usual, it is a tight fit when the bonnet is closed. This causes either side of my bonnet to not line up as well as it did before. It is a seibon carbon bonnet and here are some photos of what I am talking about. Ian, I think shaving the underside of the bonnet is an opition I need to consider. Would getting an aftermarket strut brace work instead? The front sits prefectly though Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted January 14, 2011 Share Posted January 14, 2011 Try removing the spacers that you fitted to the strut bar as you may not require them. Quote Link to comment Share on other sites More sharing options...
Chan267 Posted January 14, 2011 Author Share Posted January 14, 2011 Zmax i have tried and it doesnt fit on top on the engine cover. Going to get the underside of the bonnet skimmed Quote Link to comment Share on other sites More sharing options...
