spursmaddave Posted January 10, 2011 Share Posted January 10, 2011 Thought I would post this in case someone else has had the problem... Anyone know of the positions of the sensors, maybe just something has come loose as the problem is only intermittent... ABS, TC & Slip light all come on and when Mark @ Abbey ran the code it was C1142, he hasn't seen it before and googling has only shown up a couple of links all a bit vague... Quote Link to comment Share on other sites More sharing options...
Ricey Posted January 10, 2011 Share Posted January 10, 2011 One I test drove had the same problem. They replaced the sensor.....not sure where its located but it think they can sometimes be cleaned up. ......although if your prepared to give your missus a blank cheque for a ring I'm sure you can stretch to a new sensor! Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted January 10, 2011 Share Posted January 10, 2011 It is on the control unit beside the servo. Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted January 10, 2011 Author Share Posted January 10, 2011 It is on the control unit beside the servo. Cheers Alex... if only I knew where the Control Unit was Haven't had any lights since Friday and used the car everyday... very strange Quote Link to comment Share on other sites More sharing options...
Greg Warnes Posted January 10, 2011 Share Posted January 10, 2011 Look at item 3 of the attached PDF Quote Link to comment Share on other sites More sharing options...
Ricey Posted January 10, 2011 Share Posted January 10, 2011 It's probably got a bit crapped up which intermittently interferes with its reading. The 2 times I've seen it happen its needed a new one. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted January 10, 2011 Share Posted January 10, 2011 It is on the control unit beside the servo. Cheers Alex... if only I knew where the Control Unit was Haven't had any lights since Friday and used the car everyday... very strange Beside the brake servo Dave under the plastic cover where you are supposed to check your brake fluid on a regular basis. Quote Link to comment Share on other sites More sharing options...
Ricey Posted January 10, 2011 Share Posted January 10, 2011 It's probably got a bit crapped up which intermittently interferes with its reading. The 2 times I've seen it happen its needed a new one. it would appear I'm talking about a different sensor....I'll be quiet now Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted January 11, 2011 Author Share Posted January 11, 2011 Look at item 3 of the attached PDF Thanks Greg, top man Beside the brake servo Dave under the plastic cover where you are supposed to check your brake fluid on a regular basis. :lol: I checked the fluid when the light first came on... I have absolutely no technical knowledge I am just hoping that maybe something is loose or covered in crap... Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted January 24, 2011 Author Share Posted January 24, 2011 All sorted by Charlie @ Abbey this morning along with a P2 service Turned out it was a VERY simple fix, a brake light switch that was not sending a signal to the ECU or ABS hence causing the Christmas Tree effect on the dash... All sorted for £20 on top of the service Quote Link to comment Share on other sites More sharing options...
slidemotorsport Posted January 26, 2011 Share Posted January 26, 2011 any more info on that fix?? was it actually the brake light switch?? Quote Link to comment Share on other sites More sharing options...
Mark@Abbey m/s Posted January 26, 2011 Share Posted January 26, 2011 Yep just the brake light switch, the car is pretty clever it see's an increase in brake pressure but no brake lights so throws a CEL. Quote Link to comment Share on other sites More sharing options...
slidemotorsport Posted January 27, 2011 Share Posted January 27, 2011 got the same code coming up on mine, lookd at the abs pressure sensor and saw a connector broken and disconnected near it, black one end and grey the other??, pinned it back together copying the wiring off my other zed and it turned off all the lights on the dash that were lite up so was well chuffed. went to drive home and it just kinda goes into a sort of proper slow limp mode and the traction control light flashes up??? clutch in and it'l rev ok?? just disconneted the pins again to come home so i'll have another look tomorrow but have you any ideas?? Quote Link to comment Share on other sites More sharing options...
Mark@Abbey m/s Posted January 27, 2011 Share Posted January 27, 2011 got the same code coming up on mine, lookd at the abs pressure sensor and saw a connector broken and disconnected near it, black one end and grey the other??, pinned it back together copying the wiring off my other zed and it turned off all the lights on the dash that were lite up so was well chuffed. went to drive home and it just kinda goes into a sort of proper slow limp mode and the traction control light flashes up??? clutch in and it'l rev ok?? just disconneted the pins again to come home so i'll have another look tomorrow but have you any ideas?? Are your cars both UK? Uk and JDM wiring are dofferent we have found. Post some pictures up please , cant really work out what you are talking about re connectors. To sort these problems we really need a Consult Nissan diagnostic machine thou. Quote Link to comment Share on other sites More sharing options...
slidemotorsport Posted January 27, 2011 Share Posted January 27, 2011 i'll take a pic and stick it up later. ive got some basic nissan diag software and nistune but a mates got the cable at the minute thanks Quote Link to comment Share on other sites More sharing options...
