Lyger Posted January 10, 2011 Share Posted January 10, 2011 Can anyone help with this problem? Car was braking fine until yesterday when i started the car it came up with the brake warning light that wouldnt clear and the brake pedal is now at the bottom of its travel when i brake and its very scary to drive now ? The front disc and pads are just about Knackered on there minimum limit was due to change these at the end of the month. The fluid has not gone down in the resevoir albeit just a tiny amount. Im going to change the Pads and discs tomorrow but havent a clue where to begin with the Master Cylinder if it is this, Where can i get one from and is it easy to fit? Do the uk spec parts fit the Jap model and is it better to take it to nissan and remortgage the house ?? Thanks Quote Link to comment Share on other sites More sharing options...
BladesGrant Posted January 10, 2011 Share Posted January 10, 2011 If you need parts or advice you should or :pmr35lee: Quote Link to comment Share on other sites More sharing options...
