philb1965 Posted January 9, 2011 Share Posted January 9, 2011 I recently bought a G220 and plan to have a go improving the paint condition on my daughters Toyota Aygo before I do the Z Now I usually clay then use megs step 1 paint cleaner by hand on a full clean. I'd like to use the DA to take some of the strain out of it but I'm not sure about a couple of things. What paint cleanser could I use with the DA? Any recommendations other than the step1? I've only got one polishing and one finishing pad. I'm guessing I'd use the polishing pad for the cleaner but would I then need to clean it before applying polish? Do I need to buy a seperate pad for the cleaner? Any advice welcome, cheers. Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted January 9, 2011 Share Posted January 9, 2011 seperate pad for the polish if your doing it properly. megs paint cleaner would do the job, or dodo juice lime and prime. Quote Link to comment Share on other sites More sharing options...
bodyboarder Posted January 9, 2011 Share Posted January 9, 2011 Ya dodo lime prime is great , just make sure you only use a very small amount as its very oily Quote Link to comment Share on other sites More sharing options...
Envy Valeting Posted January 9, 2011 Share Posted January 9, 2011 Hi Phil, I'd recommend Dodo Juice Lime prime if the paint is less than perfect ie the odd swirl/scratch/oxidation etc. If the paint is pretty swirl free I'd plump for Lime prime lite. Lime prime has microabrasives, and the lime prime lite doesn't. You can find them both in my shop https://www.envyvaleting.com/products_info.asp?id=125 https://www.envyvaleting.com/products_info.asp?id=113 I've not got round to upping the VAT yet, so at last years prices still and if you use the code 350z at checkout you'll get a nice Brucie bonus Cheers Tim Quote Link to comment Share on other sites More sharing options...
philb1965 Posted January 9, 2011 Author Share Posted January 9, 2011 Hi Tim The Aygo has been well abused! I've been thinking about it and initially for that I don't need a cleaner as I'm going to use some Megs Ultimate Compound on it. Is that right? Once it's improved I guess I'd just need the lime prime lite to clean. I don't want anything abrasive on the Z as it's fairly swirl free. So I guess I just need another yellow polishing pad and lime prime lite? I'll then top it off with either SRP or poorboys EX-P and a coat of HD Wax. Can you recommend a wheel cleaner and wheel wax as well please! Cheers. Quote Link to comment Share on other sites More sharing options...
Ricey Posted January 9, 2011 Share Posted January 9, 2011 Thanks to Tim I've just done my ooberscratched Lancer with the G220 and Megs ultimate and feck-a-doodle-doo..............the paint is like glass! Quote Link to comment Share on other sites More sharing options...
philb1965 Posted January 9, 2011 Author Share Posted January 9, 2011 Good to hear, hopefully have a crack at the Aygo in the next couple of weeks weather permitting. How long did it take? Quote Link to comment Share on other sites More sharing options...
Ricey Posted January 9, 2011 Share Posted January 9, 2011 Good to hear, hopefully have a crack at the Aygo in the next couple of weeks weather permitting. How long did it take? Took about 20-30 mins to apply the Megs with the machine but I applied the wax by hand as wasn't really sure how to get the Dodo Juice Wax onto the pad!.....I washed, polished, waxed, hoovered, gliptone cleaned/conditioned leather and tyre blacked the both Lancer and the Zed over about a 7 hour period It got to that horrific point of the day where winter dusk sets in and the condensation was sitting on the car before I could get the wax off......I feel like I've been rogered by Mr Miyagi!! Quote Link to comment Share on other sites More sharing options...
Cragus Posted January 9, 2011 Share Posted January 9, 2011 Can't wait to unleash the G220 on my zed. Waiting for the service to be comepleted first though - ok - warmer weather to come in Quote Link to comment Share on other sites More sharing options...
Envy Valeting Posted January 10, 2011 Share Posted January 10, 2011 Hi Tim The Aygo has been well abused! I've been thinking about it and initially for that I don't need a cleaner as I'm going to use some Megs Ultimate Compound on it. Is that right? Once it's improved I guess I'd just need the lime prime lite to clean. I don't want anything abrasive on the Z as it's fairly swirl free. So I guess I just need another yellow polishing pad and lime prime lite? I'll then top it off with either SRP or poorboys EX-P and a coat of HD Wax. Can you recommend a wheel cleaner and wheel wax as well please! Cheers. No problem at all Phil. Yes once you've ultimate compounded you should only need Lime prime lite from there on in, but its recommended usage is bi-annually so you wount have to do it too often. I have another yellow pad, if you want me to put one to one side? Wheel cleaner wise depends if you have chrome or a non standard finish? If you have the standard powder coated wheels I'd recommend Espuma Revolution which comes in 1 or 5L sizes, dilutes 10:1 and I love it. https://www.envyvaleting.com/products_info.asp?id=152 If you do have more exotic wheels I'd suggest one of the Wolfs Chemicals products. 1 is a straight forward cleaner https://www.envyvaleting.com/products_info.asp?id=239 works well, smells vile and is 1L volume but its not dilutable The other they do is a clean and coat, https://www.envyvaleting.com/products_info.asp?id=240 Personally speaking I'd suggest going for something like the Revolution, and get a special sealent as in the long run will work out to be better value https://www.envyvaleting.com/products_info.asp?id=255 I know the rim sealent seems a small bottle but you use so little per application and I've been impressed with it in testing. Cheers Tim Quote Link to comment Share on other sites More sharing options...
Envy Valeting Posted January 10, 2011 Share Posted January 10, 2011 Can't wait to unleash the G220 on my zed. Waiting for the service to be comepleted first though - ok - warmer weather to come in Sheesh Craig! You shouted the loudest at wanting to get your hands on the G220 1st and now you tell us this confession...fair weather detailer Quote Link to comment Share on other sites More sharing options...
philb1965 Posted January 10, 2011 Author Share Posted January 10, 2011 Hi Tim The Aygo has been well abused! I've been thinking about it and initially for that I don't need a cleaner as I'm going to use some Megs Ultimate Compound on it. Is that right? Once it's improved I guess I'd just need the lime prime lite to clean. I don't want anything abrasive on the Z as it's fairly swirl free. So I guess I just need another yellow polishing pad and lime prime lite? I'll then top it off with either SRP or poorboys EX-P and a coat of HD Wax. Can you recommend a wheel cleaner and wheel wax as well please! Cheers. No problem at all Phil. Yes once you've ultimate compounded you should only need Lime prime lite from there on in, but its recommended usage is bi-annually so you wount have to do it too often. I have another yellow pad, if you want me to put one to one side? Wheel cleaner wise depends if you have chrome or a non standard finish? If you have the standard powder coated wheels I'd recommend Espuma Revolution which comes in 1 or 5L sizes, dilutes 10:1 and I love it. https://www.envyvaleting.com/products_info.asp?id=152 If you do have more exotic wheels I'd suggest one of the Wolfs Chemicals products. 1 is a straight forward cleaner https://www.envyvaleting.com/products_info.asp?id=239 works well, smells vile and is 1L volume but its not dilutable The other they do is a clean and coat, https://www.envyvaleting.com/products_info.asp?id=240 Personally speaking I'd suggest going for something like the Revolution, and get a special sealent as in the long run will work out to be better value https://www.envyvaleting.com/products_info.asp?id=255 I know the rim sealent seems a small bottle but you use so little per application and I've been impressed with it in testing. Cheers Tim Thanks Tim, put the pad to one side for me and I'll put an order in on your website. Cheers Phil Quote Link to comment Share on other sites More sharing options...
philb1965 Posted January 10, 2011 Author Share Posted January 10, 2011 Hi Tim Ordered some stuff...the code didn't work though. Cheers Phil Quote Link to comment Share on other sites More sharing options...
Envy Valeting Posted January 10, 2011 Share Posted January 10, 2011 Hi Tim Ordered some stuff...the code didn't work though. Cheers Phil Hi Phil, the code would have worked if you'd ordered the Dodo Lime Prime or lime prime lite I did however (before reading this above) do you a nice discount on the order anyway as a thankyou for the repeat business Best wishes Tim ps you have an email Quote Link to comment Share on other sites More sharing options...
philb1965 Posted January 10, 2011 Author Share Posted January 10, 2011 Tim I'm a donut. I forgot to order the lime prime lite! Can you add it to my order? Cheers phil Quote Link to comment Share on other sites More sharing options...
Envy Valeting Posted January 10, 2011 Share Posted January 10, 2011 Not a problem Phil Quote Link to comment Share on other sites More sharing options...
Ricey Posted January 10, 2011 Share Posted January 10, 2011 Fair play........Tim rules I was polishing like a demon with my new pads yesterday! Quote Link to comment Share on other sites More sharing options...
clarkie34 Posted January 10, 2011 Share Posted January 10, 2011 Hi Tim, Just placed an order for some of the Wolfs wheel cleaner. Quote Link to comment Share on other sites More sharing options...
Envy Valeting Posted January 10, 2011 Share Posted January 10, 2011 Fair play........Tim rules I was polishing like a demon with my new pads yesterday! Good man, get stuck in Quote Link to comment Share on other sites More sharing options...
Envy Valeting Posted January 10, 2011 Share Posted January 10, 2011 Hi Tim, Just placed an order for some of the Wolfs wheel cleaner. Thanks very much Wayne, will be in the post to you tomorrow.Love to hear your feedback on it. Quote Link to comment Share on other sites More sharing options...
clarkie34 Posted January 10, 2011 Share Posted January 10, 2011 Hi Tim, Just placed an order for some of the Wolfs wheel cleaner. Thanks very much Wayne, will be in the post to you tomorrow.Love to hear your feedback on it. By the sounds of it it should do 2 jobs in one,ill let you know how it goes. Quote Link to comment Share on other sites More sharing options...
Envy Valeting Posted January 10, 2011 Share Posted January 10, 2011 Hi Tim, Just placed an order for some of the Wolfs wheel cleaner. Thanks very much Wayne, will be in the post to you tomorrow.Love to hear your feedback on it. By the sounds of it it should do 2 jobs in one,ill let you know how it goes. It does indeed Wayne, but as you know everyone has different opinions on how well stuff works/or doesnt work so its useful to get opinions other than my own Quote Link to comment Share on other sites More sharing options...
