Led question
Dblock
Go to Maplin/Fleabay and buy a "Step Down Transformer!!"
(Its What us old folk used on our train sets!)
Make sure you buy the right one! :blackeye:
IE I've got no idea but I'm sure you could find out! :bangin:
Maplin for Geek Advice then Fleabay for Price!!!
Sorted!
Cheers, if they had a plug I could get a converter but it's just 2 wires. Il have a look for the step down. Cheers
Sorted!
SMD means surface mounted device, they are the type that are soldered directly onto circuit boards and dont have wires trailing from them.
The most common type of LED is 5mm. for simplicity look for ones that already have the correct resistor for 12V (or whatever voltage you want to work at) attached with wires to connect up with.
for a power supply you can go shopping at maplin or ebay as suggested for a 12V or 5V or whatever rating you want to go with. They will have a mA rating aswell but if you arent using many LED's it barely matters about this. There are other things you can use but i dont want to go telling you to stab wires in random plugs.
Just the man I wanted to hear from. These smd LEDs are quite cool. The run at 12v I take it 5v would be if I wanted them dimmer? These are also 5mm flat tops which IMO look better than round tops although they will be hidden only the light will come out.
Is there any particular LEDs that are better or brighter than others as I'm using it somewhere well lit anyway. Il be going for a strip around 5m.
Thanks
Sorted!
It’s about 40yrs since I studied electronics and things have moved on a pace since then so I hope this will still be valid.
Led’s are a dc devices with +ve and 0v connections, so a step down transformer on its own wouldn’t be sufficient as the lower voltage output from the transformer would still be ac.
You would now need to convert it to dc by rectifying it with a bridge rectifier. Something in the order of a 9v ac output from the transformer, when rectified, would give approx 12v dc.
Before connecting the led to the dc output you would need to know the forward voltage and current of youre led in order to calculate the correct size of resistor to protect it (by connecting the resistor in series with the +ve connection of the led to limit the current that would flow through it)
Hope it helps and is still current :wacko:
Thanks
i would probably suggest for simplicity to get premade stips of LED's which you can also buy power supplies for that match. this makes it nice and simple to get them put together. also they will give you the correct spread of light.
