SparksCW Posted December 24, 2010 Share Posted December 24, 2010 My air bag warning light randomly started flashing today. It was fine until I gunned it from the lights, not sure how that would affect it???? I Have recently fitted a JWT pop charger and havent reset ecu but again dont see how that would affect it. I take it it needs to go to a dealer/garage now then? Quote Link to comment Share on other sites More sharing options...
bounty78 Posted December 24, 2010 Share Posted December 24, 2010 Mine came on the other day as well when it was -8 degrees Some people say the airbag light comes on if you have moved your seat bcos of the wiring underneath the seat. I haven;t done anything to mine..it just came on one morning Try this..it worked for me..seems to have sorted out the problem Quote Link to comment Share on other sites More sharing options...
Roo Posted December 25, 2010 Share Posted December 25, 2010 Mine got set off by something sliding under the seat. Did the reset not been a problem since. Quote Link to comment Share on other sites More sharing options...
SparksCW Posted December 25, 2010 Author Share Posted December 25, 2010 Mine got set off by something sliding under the seat. Did the reset not been a problem since. Hmmm I did have a box on the seat and some stuff behind the seat which did move when it happened. I guess it was that, I'll do the reset and see what happens Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted December 25, 2010 Share Posted December 25, 2010 Common problem ..... do the reset and all should be OK Quote Link to comment Share on other sites More sharing options...
SparksCW Posted December 27, 2010 Author Share Posted December 27, 2010 i did the reset which worked fine, but its come on again now. the only thing is i had bags etc on the seat and in the footwell again. ill reset it again and see what happens Quote Link to comment Share on other sites More sharing options...
ChrisS Posted December 27, 2010 Share Posted December 27, 2010 It's worth getting you hands under the seat and making sure the connections are good. Mine are now tie wrapped. Quote Link to comment Share on other sites More sharing options...
R35LEE Posted December 27, 2010 Share Posted December 27, 2010 We see this loads. It is nearly always a bottle of water or coke rolling around under the seat. Tie wrap on the srs loom inder the seat helps as it stops the wire from jerking out when a bottle hits it Quote Link to comment Share on other sites More sharing options...
M13KYF Posted December 28, 2010 Share Posted December 28, 2010 or possible break in the loom in the rear of the seat. Simple bit of soldering the damaged wire will fix it. I had this problem Quote Link to comment Share on other sites More sharing options...
Nolan Posted December 28, 2010 Share Posted December 28, 2010 I had this problem too, i posted the same question in another thread and was told about the reset precedure, did it a couple of hours ago, worked a treat. Will see how it goes tomorrow. Quote Link to comment Share on other sites More sharing options...
cmck13 Posted July 19, 2011 Share Posted July 19, 2011 I just did the reset as per the u-tube video on here and it works, I wasn't holding out that this would happen being Mr Cynical and I thought here we go its a trip to the dealer. Absolutely great something that does what it says. Quote Link to comment Share on other sites More sharing options...
HassanZ Posted July 19, 2011 Share Posted July 19, 2011 If the light comes back on, that means the air bag wire under the passenger seat has been moved out of place. Get some zip ties and tie the wires down to ensure they're secure. Quote Link to comment Share on other sites More sharing options...
bounty78 Posted July 19, 2011 Share Posted July 19, 2011 I just did the reset as per the u-tube video on here and it works, I wasn't holding out that this would happen being Mr Cynical and I thought here we go its a trip to the dealer.Absolutely great something that does what it says. i have finally posted something useful on the forum after 1338posts Quote Link to comment Share on other sites More sharing options...
Keviswatt Posted July 19, 2011 Share Posted July 19, 2011 Mine came on the other day as well when it was -8 degrees Some people say the airbag light comes on if you have moved your seat bcos of the wiring underneath the seat. I haven;t done anything to mine..it just came on one morning Try this..it worked for me..seems to have sorted out the problem +1 ...worked for me Quote Link to comment Share on other sites More sharing options...
nzr350z Posted September 15, 2011 Share Posted September 15, 2011 +1,000,000,worked for me too Quote Link to comment Share on other sites More sharing options...
bronzee Posted September 16, 2011 Share Posted September 16, 2011 Maybe also check the cabling under the seats too, just in case something is starting to work loose. Quote Link to comment Share on other sites More sharing options...
