mike89 Posted December 22, 2010 Share Posted December 22, 2010 Had a search and didnt find much info. Does anybody know where this fuse is? Checked the fuses at the battery but only found the headlight washer fuses. The nissan manual is not very clever either! I want to check the fuses because I cant even hear the pump making a noise at all when I try it. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted December 22, 2010 Share Posted December 22, 2010 Had a search and didnt find much info. Does anybody know where this fuse is? Checked the fuses at the battery but only found the headlight washer fuses. The nissan manual is not very clever either! I want to check the fuses because I cant even hear the pump making a noise at all when I try it. Probably may just be frozen Mike. Quote Link to comment Share on other sites More sharing options...
mike89 Posted December 22, 2010 Author Share Posted December 22, 2010 Yeah I did think that was the case Alex but I cant even hear it trying to pump, usually when the anti freeze is frozen you can hear the pump trying to work and no water comes out! Unless you mean the pump itself is frozen? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted December 22, 2010 Share Posted December 22, 2010 Unless you mean the pump itself is frozen? Yeah, that is what I meant. Quote Link to comment Share on other sites More sharing options...
mike89 Posted December 22, 2010 Author Share Posted December 22, 2010 Unless you mean the pump itself is frozen? Yeah, that is what I meant. aye its a possibility! Do you know where the fuse is for it anyway and I will check it? Quote Link to comment Share on other sites More sharing options...
ray350gt4 Posted December 22, 2010 Share Posted December 22, 2010 http://www.google.co.uk/imgres?imgurl=h ... CC4Q9QEwCA link to fuse location but i think the washers and wipers use same fuse Quote Link to comment Share on other sites More sharing options...
buster Posted December 22, 2010 Share Posted December 22, 2010 http://www.google.co.uk/imgres?imgurl=http://img530.imageshack.us/img530/8770/9600civicfuse98civicexatb2.jpg&imgrefurl=http://www.d-series.org/forums/audio-electronics/121595-defi-link-controller-install-question.html&h=660&w=502&sz=79&tbnid=fljZe8WhvzzcvM:&tbnh=138&tbnw=105&prev=/images%3Fq%3D350z%2Bfuse%2Bbox%2Bdiagram&zoom=1&q=350z+fuse+box+diagram&usg=__hx_ZdVM5WgB0s5y6QGm_pn_4k5U=&sa=X&ei=Oz8STb_vEsXLhAerlYm3Dg&ved=0CC4Q9QEwCAlink to fuse location but i think the washers and wipers use same fuse forgive me but it says that the fuse box of a 98 civic Quote Link to comment Share on other sites More sharing options...
