drivebyabuser Posted December 15, 2010 Share Posted December 15, 2010 Just getting to grips with the new zed - mostly loving it - Cant stop driving past high walls and plate glass shops! One of the issues i have is that when cold its hard to get it in to second gear. It seems quite notchy - takes a little more force than i feel it should and more than the other ratios. Once warm though it seems fine. Is this common? any ideas? I will take it for a service in the next month or so and get them to change the gear box oil to see if that has any effect. Quote Link to comment Share on other sites More sharing options...
Vik54 Posted December 15, 2010 Share Posted December 15, 2010 Yup - common issue. You either learn to live with it or get a new gear box I had gear box oil changed but it made no discernable difference - though addition of Molyslip might help - available here http://www.350z-uk.com/forum/viewtopic.php?f=157&t=43465 Quote Link to comment Share on other sites More sharing options...
drivebyabuser Posted December 15, 2010 Author Share Posted December 15, 2010 Vik54 said: Yup - common issue. You either learn to live with it or get a new gear box I had gear box oil changed but it made no discernable difference - though addition of Molyslip might help - available here http://www.350z-uk.com/forum/viewtopic.php?f=157&t=43465 Thanks for that - Just didnt want to think my 'box was on the way out! This sports car lark is not cheap! Quote Link to comment Share on other sites More sharing options...
drivebyabuser Posted December 15, 2010 Author Share Posted December 15, 2010 drivebyabuser said: Vik54 said: Yup - common issue. You either learn to live with it or get a new gear box I had gear box oil changed but it made no discernable difference - though addition of Molyslip might help - available here http://www.350z-uk.com/forum/viewtopic.php?f=157&t=43465 Just another thing - Does everything good come from Had the car 3 weeks and already i speak to him more than my missus! Quote Link to comment Share on other sites More sharing options...
R35LEE Posted December 15, 2010 Share Posted December 15, 2010 Try short shifting to thrid when you can mate. I have 2 gearboxes being rebuilt now and I will offer an exchange when they are done :pmr35lee: If the problem starts to annoy you as it will continue to worsen in most cases then get in touch. Quote Link to comment Share on other sites More sharing options...
drivebyabuser Posted December 15, 2010 Author Share Posted December 15, 2010 R35LEE said: Try short shifting to thrid when you can mate. I have 2 gearboxes being rebuilt now and I will offer an exchange when they are done :pmr35lee: If the problem starts to annoy you as it will continue to worsen in most cases then get in touch. Cheers - Sorry i know good things come from :pmr35lee: too but i just havent had a chance to use you yet! Where are you based and what kind of cost am i looking at for an exchange? Quote Link to comment Share on other sites More sharing options...
JetSet Posted December 15, 2010 Share Posted December 15, 2010 Yeah, mine's been notchy from brand new, it improves as the car warms up but even then its not as smooth as it should be. My wife's roadster has the same notchy second gear but it completely goes away after a couple of miles . I've no idea if Nissan made any changes to the gear box on the later models, could just be differences from car to car. I've learned to live with it, just making the gear change a bit slower will mask it to a degree, anyway, it's nothing to be concerned about. Pete Quote Link to comment Share on other sites More sharing options...
Vik54 Posted December 15, 2010 Share Posted December 15, 2010 Mine has only ever done it when freezing cold and improves as soon as warmed up - its never got any worse- its just a bit annoying - I contemplated a re-build and new box but decided more trouble than its worth - as Lee suggests generally driving with a bit of 'mechanical sympathy' when its cold does the trick Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted December 15, 2010 Share Posted December 15, 2010 Common issue mate and you will soon get used to it, just got to change your driving style slightly and in a few weeks you will wonder what all the drama was about. No need to waste your hard earned on a replacement gearbox. Quote Link to comment Share on other sites More sharing options...
defianty Posted December 15, 2010 Share Posted December 15, 2010 Yeah mine does this too. I thought it may be an issue but saw that it's a common problem and have now forgotten about it. To be honest it only happens when it's really cold and it fine after half a dozen changes. I'll call it character Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted December 15, 2010 Share Posted December 15, 2010 just double clutch while its cold once warm swap back to normal. double clutching seems to sort the synco's out so you can find the gear. Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted December 15, 2010 Share Posted December 15, 2010 what Rich said Quote Link to comment Share on other sites More sharing options...
drivebyabuser Posted December 15, 2010 Author Share Posted December 15, 2010 Glad its a "quirk" Will have to learn to double de clutch properly now, then teach mrs drivebyabuser...... Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted December 15, 2010 Share Posted December 15, 2010 drivebyabuser said: Glad its a "quirk" Will have to learn to double de clutch properly now, then teach mrs drivebyabuser...... in gear (likely 3rd but could be another) press clutch pop out of gear, lift clutch. push clutch down again select 2nd. lift clutch basically use the clutch twice instead of doing it all in one change. the lift and drop on a double clutch change seems to straight/re align the syncros between changes. once the gear box oil is all nice and warm the syncro's are far more compliant. Quote Link to comment Share on other sites More sharing options...
