Window wiper death!
D0rzi
Most wipers are fitted on a conicle spline.
Can you tighten it down ? or has the spline gone ?
If the spline has worn away,a stop gap would be loctite (then a bugger to get off later) or some insulation tape round the spline and re-tighten the nut.
If it's not the arm that has slipped on the spline it could be a rod has popped off under the plastic scuttle panel at the botton of the screen.
Let us know what the outcome is. I have arms, motors and mechanisms sat here in stock if any are needed :thumbs:
