Grundy Posted February 8, 2015 Share Posted February 8, 2015 Boom, So it's been quite a few years since this thread.... Going to be purchasing some coilovers this week. What would be required if I went True Coil? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted February 9, 2015 Share Posted February 9, 2015 Since the std spring position is in a different place, you would need to strengthen the original shock mounts to be able to cope with the extra load, bit of a pain when you can get coil and shock setup which does exactly the same thing, there is no advantage in running a genuine coil over set up on the rear. 2 Quote Link to comment Share on other sites More sharing options...
Grundy Posted February 9, 2015 Share Posted February 9, 2015 Since the std spring position is in a different place, you would need to strengthen the original shock mounts to be able to cope with the extra load, bit of a pain when you can get coil and shock setup which does exactly the same thing, there is no advantage in running a genuine coil over set up on the rear. Thanks buddy. I thought I posted in this thread yesterday, but I could never find it again Quote Link to comment Share on other sites More sharing options...
glrnet Posted February 9, 2015 Share Posted February 9, 2015 Since the std spring position is in a different place, you would need to strengthen the original shock mounts to be able to cope with the extra load, bit of a pain when you can get coil and shock setup which does exactly the same thing, there is no advantage in running a genuine coil over set up on the rear. Thanks buddy. I thought I posted in this thread yesterday, but I could never find it again Just use the filter "items I participated in" Quote Link to comment Share on other sites More sharing options...
Grundy Posted February 9, 2015 Share Posted February 9, 2015 Since the std spring position is in a different place, you would need to strengthen the original shock mounts to be able to cope with the extra load, bit of a pain when you can get coil and shock setup which does exactly the same thing, there is no advantage in running a genuine coil over set up on the rear. Thanks buddy. I thought I posted in this thread yesterday, but I could never find it again Just use the filter "items I participated in" I did :/ Did what I did and manually went to the sub thread where this is, couldn't find this thread. View my content, nothing Just vanished. Quote Link to comment Share on other sites More sharing options...
Freebird Posted February 9, 2015 Share Posted February 9, 2015 Apparently I posted in here way back when...I still have not had any issues with my XZY's. I have not done any additional modifications. However a cage is a possibility in the future. Quote Link to comment Share on other sites More sharing options...
