walt350z Posted December 5, 2010 Share Posted December 5, 2010 Hi read the posts about this problem,so done the test and came up with 10 slow.3 fast.4 fast.10 fast flashing lights,will this mean the code is 0340 CMP (Cam Shaft Position) Sensor (Phase is this bad or an easy fix cheers, Walt Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted December 5, 2010 Share Posted December 5, 2010 Hiread the posts about this problem,so done the test and came up with 10 slow.3 fast.4 fast.10 fast flashing lights,will this mean the code is 0340 CMP (Cam Shaft Position) Sensor (Phase is this bad or an easy fix cheers, Walt Hi Walt, Swopping out the CPS is an easy fix mate if indeed that is the fault. There is one on each of the rear of the cyl.heads so you will have to identify which one is faulty if indeed there is a fault. If the car is running fine then best to carry out a reset and see if the light comes back on again as it may just be a glitch. If it does come back on then pull the code and compare. If you require a CPS then I have both the sensors for Bank 1 and Bank 2 in stock. Alex. Quote Link to comment Share on other sites More sharing options...
