jay3032 Posted December 3, 2010 Share Posted December 3, 2010 Are the dealers the only place I can purchase a can of Azure spray paint, I would like to spray some interior panels, any tips on Prep? Thanks Quote Link to comment Share on other sites More sharing options...
stanski Posted December 3, 2010 Share Posted December 3, 2010 No any good quality local car parts shop can mix up a tin or spray can for you or worse go to Halfrauds. Re: Prep - depends what you want to spray I guess the plastic panels? Tricky paint does'nt like flexible plastic - you need to buy a primer for plastics - such as a bumper primer which flexes with the plastic, however generally in my experience durability is still an issue - better off covering in a matching vinyl or leather? If you do decide to spray then ensure the area is very clean and you may have to rough it up a bit with some very fine wet and dry paper or sandpaper first, apply primer , dry then apply another coat etc then paint, dry , sand , repeat until you get the finish you want? Hope this helps? Quote Link to comment Share on other sites More sharing options...
cmck13 Posted December 3, 2010 Share Posted December 3, 2010 Have a look at this site most Z users obtain their paint requirements from them. I have an azure and they supplied a very good match, plastic is tricky as said in previous answer. However I did my engine bay (bling) battery cover etc and looks great but of course these bits don't get constant use every day. http://www.paints4u.com/default.aspx Quote Link to comment Share on other sites More sharing options...
glrnet Posted December 3, 2010 Share Posted December 3, 2010 ^^^^ http://www.paints4u.com/default.aspx These people are really helpful, give them a call and tell them what you're trying to achieve, they should advise accordingly. Quote Link to comment Share on other sites More sharing options...
R35LEE Posted December 3, 2010 Share Posted December 3, 2010 If you are planning on doing the centre trim and cubby make sure you try and get off the rubber / pastic top layer as it reacts when painted due to silicone. Ask Madmarky as his first one did this. Secondly use a decent quality high build primer. Paint can be sourced for nearly any Auto supply company like fleet factors / halfords / etc etc. If I was you do some of the prep yourself and find out if anyone on here is getting any paintwork done on an azure zed. Then just ask if you can get it done when their car goes in. Will be the cheapest option and hopefully get the best results Quote Link to comment Share on other sites More sharing options...
Goldcrest Four Posted December 3, 2010 Share Posted December 3, 2010 I used paints4U (about £12 for a very generous can)) for stonechips on my GM - the match was excellent, undetectable from the original, was very pleased. They will also make up an aerosol for you it you prefer, just give them your paint code. Quote Link to comment Share on other sites More sharing options...
jay3032 Posted December 3, 2010 Author Share Posted December 3, 2010 Thanks for the advice, much appreciated Quote Link to comment Share on other sites More sharing options...
