djrm Posted November 30, 2010 Share Posted November 30, 2010 Hi guys! I am after a replacement HU for my 350, get rid of the useless Bose.. I already have a system from Nurrish and would like to use the reverse cam input as an input from a Single DIN DVD player.. Can this be done? Use the Nurrish system as the screen for the DVD? Any help is appreciated! Thanks! Ryan Quote Link to comment Share on other sites More sharing options...
djrm Posted November 30, 2010 Author Share Posted November 30, 2010 Something like this? http://cgi.ebay.co.uk/Sony-mex-dv800-si ... _687wt_907 Quote Link to comment Share on other sites More sharing options...
Zugara Posted November 30, 2010 Share Posted November 30, 2010 Sparky fitted one not so long ago, check out his threads. Quote Link to comment Share on other sites More sharing options...
djrm Posted November 30, 2010 Author Share Posted November 30, 2010 Sparky fitted one not so long ago, check out his threads. will do! Thanks Quote Link to comment Share on other sites More sharing options...
djrm Posted November 30, 2010 Author Share Posted November 30, 2010 memberlist.php?mode=viewprofile&u=42 This Sparky? He only has 1 post? Quote Link to comment Share on other sites More sharing options...
buster Posted November 30, 2010 Share Posted November 30, 2010 i ve got a sony mex-r1 fitted in mine running reverse cam and seperate sony screen.Sound bit of kit and pretty straight forward to wire in. Quote Link to comment Share on other sites More sharing options...
buster Posted November 30, 2010 Share Posted November 30, 2010 http://www.350z-uk.com/forum/memberlist.php?mode=viewprofile&u=42 This Sparky? He only has 1 post? think it was sparky350z ? Quote Link to comment Share on other sites More sharing options...
sparky370z Posted November 30, 2010 Share Posted November 30, 2010 Hello there!!! I added a cam to the back of the car. Can't you add a component cable to the aux input of the car computer? I don't know if nurrish systems have this. But yes a cam input would do I suppose. Not sure how u would get the audio tho. At some point I'm gonna add a 3.5 audio/video lead into the cubby. So I can run my media player. My HU has an aux in. Quote Link to comment Share on other sites More sharing options...
djrm Posted November 30, 2010 Author Share Posted November 30, 2010 That sounds perfect, as for the audio, the speakers will be directly connected to the HU where the DVD will be playing from so that's where the sound comes from. The picture will just come from the video output on the HU and into the input on the satnav so all should be well! Thanks for the info guys, just emailed caraudiosecurity to see if they can get the one I showed you on eBay or similar as well as the adapter to make the Bose speakers work properly and the steering controls. Thanks again! Quote Link to comment Share on other sites More sharing options...
Dblock Posted December 6, 2010 Share Posted December 6, 2010 I have a jvc avx-1 for sale? Quote Link to comment Share on other sites More sharing options...
Dblock Posted December 6, 2010 Share Posted December 6, 2010 That sounds perfect, as for the audio, the speakers will be directly connected to the HU where the DVD will be playing from so that's where the sound comes from. The picture will just come from the video output on the HU and into the input on the satnav so all should be well! Thanks for the info guys, just emailed caraudiosecurity to see if they can get the one I showed you on eBay or similar as well as the adapter to make the Bose speakers work properly and the steering controls. Thanks again! Also as you already have bose, you would be better hooking the H/U to the bose amp which powers the speakers. Bose amp will probably be louder as it will have more power and as the bose speakers run at stupid impedance e.g. 3ohm(wth!) your best off sticking with the amp. Also the bose might be high passing and low passing some of the speakers so connecting to the H/u straight might cause problems. Quote Link to comment Share on other sites More sharing options...
djrm Posted December 6, 2010 Author Share Posted December 6, 2010 I have a jvc avx-1 for sale? Does that one power the Bose speakers ok? Does it have a video out?? Quote Link to comment Share on other sites More sharing options...
Dblock Posted December 6, 2010 Share Posted December 6, 2010 I have a jvc avx-1 for sale? Does that one power the Bose speakers ok? Does it have a video out?? It could power the Bose speakers but I have a special wire with it (PAC roem nis-2) that keeps the Bose amp working. It does have a video in and out I'm sure but you would be better off checking. Is there any reason you don't want to use the Bose amp? Quote Link to comment Share on other sites More sharing options...
