370z IGN OFF Interlock Door Unlock
Chris`I
To change between auto door unlock on IGN off (default - disabled):
All doors are unlocked when the power supply position is changed from ON to OFF.
BCM outputs the unlock signal to all door lock actuators when it detects that the power supply position is
changed from ignition switch ON to OFF.
The automatic door lock/unlock function ON/OFF can be switched by performing the following operation.
1. Close all doors below (door switch OFF)
2. Turn ignition switch ON
3. Press and hold the door lock and unlock switch for 5 seconds or more in the unlock direction within 20
seconds after turning the ignition switch ON.
4. The switching is complete when the hazard lamp blinks.
OFF → ON : 2 blinks
ON → OFF : 1 blink
Note: Your post will require moderator approval before it will be visible.
