Chris`I Posted November 27, 2010 Share Posted November 27, 2010 To change between auto door lock at speed (default - disabled): Vehicle Speed Sensing Auto Door Lock All doors are locked when the vehicle speed reaches 24 km/h (15 MPH) or more. BCM outputs the lock signal to all door lock actuators when it detects that the ignition switch is turned ON, all doors are closed and the vehicle speed received from the combination meter via CAN communication becomes 24 km/h (15 MPH) or more. The automatic door lock function ON/OFF can be switched by performing the following operation. 1. Close all doors (door switch OFF) 2. Turn ignition switch ON 3. Press and hold the door lock and unlock switch for 5 seconds or more in the lock direction within 20 seconds after turning the ignition switch ON. 4. The switching is complete when the hazard lamp blinks. OFF → ON : 2 blinks ON → OFF : 1 blink Quote Link to comment Share on other sites More sharing options...
Chris`I Posted November 27, 2010 Author Share Posted November 27, 2010 Currently I have my doors set to auto lock with speed, and not to unlock with IGN. Unlock can be done by the button or opening a door from the inside. *NOTE* The lock indicator on the centre console does not dim with the rest of the dash and remains bright when lit up. Quote Link to comment Share on other sites More sharing options...
Note: Your post will require moderator approval before it will be visible.
