Chris`I Posted November 27, 2010 Share Posted November 27, 2010 To change between selective unlock enabled or disabled (default): Selective Unlock - Enabled When an LOCK signal is transmitted from Intelligent Key, all doors and fuel lid are locked. When an UNLOCK signal is transmitted from Intelligent Key once, driver side door and fuel lid are unlocked. Then, if an UNLOCK signal is transmitted from Intelligent Key again within 60 seconds, all other doors are unlocked. Selective Unlock - Disabled When an LOCK signal is transmitted from Intelligent Key, all doors and fuel lid are locked. When an UNLOCK signal is transmitted from Intelligent Key once, all doors and fuel lid are locked. Enabling/Disabling Selective Unlock When LOCK and UNLOCK signals are sent from the Intelligent Key for more than 5 seconds at the same time, hazard warning lamp blinks and Selective Unlock feature will toggle (enabled -> disabled or disabled -> enabled) Quote Link to comment Share on other sites More sharing options...
Note: Your post will require moderator approval before it will be visible.
