jay3032 Posted November 17, 2010 Share Posted November 17, 2010 I have some split rim alloy wheels, polished on the rims. Has anybody got any advice on which products to use in order to bring them back to there best, they are dull at the moment Thanks Quote Link to comment Share on other sites More sharing options...
Zugara Posted November 17, 2010 Share Posted November 17, 2010 Rim wax Quote Link to comment Share on other sites More sharing options...
sparky370z Posted November 17, 2010 Share Posted November 17, 2010 i have used autosol on the rear tailpipes, they come up uber shiny with a bit of elbow grease. same sort of thing for the polished lips i would imagine. Quote Link to comment Share on other sites More sharing options...
sparky370z Posted November 17, 2010 Share Posted November 17, 2010 Zugara said: Rim wax can u get that in ann summers? i pass by there. Quote Link to comment Share on other sites More sharing options...
jay3032 Posted November 17, 2010 Author Share Posted November 17, 2010 which autosol product have you been using pal? Quote Link to comment Share on other sites More sharing options...
Zugara Posted November 17, 2010 Share Posted November 17, 2010 sparky350z said: Zugara said: Rim wax can u get that in ann summers? i pass by there. Yeah, I think she does do rim wax......Sure aint any good for your wheels though.. Quote Link to comment Share on other sites More sharing options...
Stew Posted November 17, 2010 Share Posted November 17, 2010 woooooooooo, step away from the autosol! First thing you need to determine if the wheel rim is just polished or if it's lacquered. When you have determined this then you have a few options. Polished - Meguiars Metal Polysh is good and fairly inexpensive and works wonders on exhausts and polished rims. Then just give the wheel a good clean then top off the whole lot with rim wax or poorboys wheel sealant. The metal polysh leaves protection but it's worth topping up. Lacquered - Clean using car shampoo and work up to a wheel cleaner if it still requires work. Then top off the whole lot with rim wax or poorboys wheel sealant Quote Link to comment Share on other sites More sharing options...
sparky370z Posted November 17, 2010 Share Posted November 17, 2010 Stew said: woooooooooo, step away from the autosol! First thing you need to determine if the wheel rim is just polished or if it's lacquered. When you have determined this then you have a few options. Polished - Meguiars Metal Polysh is good and fairly inexpensive and works wonders on exhausts and polished rims. Then just give the wheel a good clean then top off the whole lot with rim wax or poorboys wheel sealant. The metal polysh leaves protection but it's worth topping up. Lacquered - Clean using car shampoo and work up to a wheel cleaner if it still requires work. Then top off the whole lot with rim wax or poorboys wheel sealant I knew somebody with much more experience would be along. Is the Meg metal polish good for stainless? Quote Link to comment Share on other sites More sharing options...
Stew Posted November 17, 2010 Share Posted November 17, 2010 sparky350z said: Stew said: woooooooooo, step away from the autosol! First thing you need to determine if the wheel rim is just polished or if it's lacquered. When you have determined this then you have a few options. Polished - Meguiars Metal Polysh is good and fairly inexpensive and works wonders on exhausts and polished rims. Then just give the wheel a good clean then top off the whole lot with rim wax or poorboys wheel sealant. The metal polysh leaves protection but it's worth topping up. Lacquered - Clean using car shampoo and work up to a wheel cleaner if it still requires work. Then top off the whole lot with rim wax or poorboys wheel sealant I knew somebody with much more experience would be along. Is the Meg metal polish good for stainless? I use it on the exhaust and my polished rims, as long as the surface isn't painted. It does have protection in it and a bit of cut so is ideal when a full on autosol isn't required. Quote Link to comment Share on other sites More sharing options...
jay3032 Posted November 17, 2010 Author Share Posted November 17, 2010 Meguiars Metal Polysh and poorboys wheel sealant ordered, Any tips on the products to use for the tyres and alloy centres? Thanks for the advice Quote Link to comment Share on other sites More sharing options...
Stew Posted November 17, 2010 Share Posted November 17, 2010 You can use an APC (all purpose cleaner) on the tyres and the arch liners to clean them up. My favourite tyre dressing is by Blackfire but the purple Meguiars stuff is pretty good. The centres of the wheels can be done with car shampoo. If that isn't strong enough then I use bilberry which has been well diluted. Check out envy valeting (forum sponsors) for products as Tim will have what you need. He does a lot of Espuma products. Oh and order a set of detailing brushes while you are at it as they are brilliant! Quote Link to comment Share on other sites More sharing options...
jay3032 Posted November 17, 2010 Author Share Posted November 17, 2010 thanks pal, you are a star Quote Link to comment Share on other sites More sharing options...
Dblock Posted November 17, 2010 Share Posted November 17, 2010 FK1000P on wheels is great, use the pressure washer and you brake dust slides off. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted November 18, 2010 Share Posted November 18, 2010 Jetseal 109 is very good wheel sealant Quote Link to comment Share on other sites More sharing options...
jay3032 Posted November 18, 2010 Author Share Posted November 18, 2010 After a lot of phoning around today the wheels are now going in for a polish and refurb (slightly kerbed) after which they will be sealed up, cheers Quote Link to comment Share on other sites More sharing options...
ryan21 Posted December 29, 2010 Share Posted December 29, 2010 For general wheel cleaning i recommend Espuma Revolution. I brought a bottle from Tim (Envy Valeting) and have been very pleased with it. I used it the other day i couldn't believe how quickly and easy the dirt came off without having to scrub it, so much better than the Autoglym, Megs and Dodo Juice wheel cleaners i've used before. Should also save money longer term as it dilutes to 1/10 so the bottle should last a while. Quote Link to comment Share on other sites More sharing options...
jhnharvy773 Posted April 3, 2012 Share Posted April 3, 2012 Wonder Wheels always worked for me although can't be sure if it causes long-term damage. The BMW salesman tried to convince me that only their cleaner was safe on their alloys _______________________ "Too much is never enough" Quote Link to comment Share on other sites More sharing options...
Dblock Posted April 3, 2012 Share Posted April 3, 2012 There stuff might be different now but before it was acid. A strong one at that. First few months would be ok but after that they will dull and be left with little protection. jhnharvy773 said: Wonder Wheels always worked for me although can't be sure if it causes long-term damage. The BMW salesman tried to convince me that only their cleaner was safe on their alloys _______________________ "Too much is never enough" Quote Link to comment Share on other sites More sharing options...
