Vik54 Posted November 16, 2010 Share Posted November 16, 2010 I use yellowstuff pads on the track and they have been fine so far. For the money they were great value. They were a massive improvement over the brembos but I've never used anything else to compare it to. I will be trying ferodo's for next year. The yellowstuff pads were fine on the roads and only get better with heat. Really pleased with them on track aswell You've changed your tune Neily! You've had your yellow stuff on for the two track days you've done and minimal road use correct? If you did higher milege and more TDs you would've needed to replace them twice over by now. My Ferrodos have been on since April so thats five track days and at least 10k miles - I've only just been given a warning to get ready to replace the fronts No-one can deny that the yellow stuff do their job for the money but surely its false economy? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted November 16, 2010 Share Posted November 16, 2010 You have got to go easy on Neily as he gets easily confused. Quote Link to comment Share on other sites More sharing options...
ben p Posted November 17, 2010 Share Posted November 17, 2010 Speedy, have you checked out DBA rotors? I recently got some of the slotted 4000 series fitted (fronts) as my OEM discs were shot, and along with the Ferodo pads mentioned above they're great - powerful with loadsa feel. The rotors are c£300 for a pair This is the set up Mark @ Abbey recommends. It's what i'll be changing to shortley. Quote Link to comment Share on other sites More sharing options...
Sized Posted November 18, 2010 Share Posted November 18, 2010 Speedy, have you checked out DBA rotors? I recently got some of the slotted 4000 series fitted (fronts) as my OEM discs were shot, and along with the Ferodo pads mentioned above they're great - powerful with loadsa feel. The rotors are c£300 for a pair This is the set up Mark @ Abbey recommends. It's what i'll be changing to shortley. Indeed, that's where I got them fitted Crackin' performance so far, and the slotted discs look much cooler than the OEM brembos Quote Link to comment Share on other sites More sharing options...
RichieB Posted November 19, 2010 Share Posted November 19, 2010 Speedy, have you checked out DBA rotors? I recently got some of the slotted 4000 series fitted (fronts) as my OEM discs were shot, and along with the Ferodo pads mentioned above they're great - powerful with loadsa feel. The rotors are c£300 for a pair This is the set up Mark @ Abbey recommends. It's what i'll be changing to shortley. Indeed, that's where I got them fitted Crackin' performance so far, and the slotted discs look much cooler than the OEM brembos on the above. I also run the same setup along with braided hoses. The feel over oem is far better and stoppin power is great when spirited driving. The only downside imo is alot of brake dust - suppose this can be expected. Just use a decent wheel wax and it cleans off fairly easily. The only time a get a little break squeal is when just town driving for a few days using very light braking. This soon disappears when back on the open roads Quote Link to comment Share on other sites More sharing options...
smudga Posted November 19, 2010 Share Posted November 19, 2010 Agree with the above ^^^^ DBA 6 wiper grooved discs & DS2500 pads best combo for me. On both my previous Imprezza STi's they had the Std Brembo set up... not good ! on the first one I tried EBC Red stuff pads std discs they lasted no time, not much improvement but distroyed the dicscs quite sucessfully. Changed to the above vast improvement and will fit the same on the Zed shortly because if you have to haul it up in a hurry standard isn't that great by comparason as I found out when some idot decided to turn right on a dual carrageway.... from the inside lane Quote Link to comment Share on other sites More sharing options...
Darren-B Posted November 19, 2010 Share Posted November 19, 2010 Agree with the above ^^^^ DBA 6 wiper grooved discs & DS2500 pads best combo for me. On both my previous Imprezza STi's they had the Std Brembo set up... not good ! on the first one I tried EBC Red stuff pads std discs they lasted no time, not much improvement but distroyed the dicscs quite sucessfully. Changed to the above vast improvement and will fit the same on the Zed shortly because if you have to haul it up in a hurry standard isn't that great by comparason as I found out when some idot decided to turn right on a dual carrageway.... from the inside lane EBC discs poo. Yellow stuffs Excellent I have tried many Brake combos including the DBAs & Ds2500s I found the Ds2500s a good pad until you get on track, they are quite a hard compound so wear the discs quickly & do not disperse heat very well. But put some YellowStuffs on with the DBAs & you will be fine Quote Link to comment Share on other sites More sharing options...
RisingPower Posted November 19, 2010 Share Posted November 19, 2010 EBC discs poo. Yellow stuffs Excellent I have tried many Brake combos including the DBAs & Ds2500s I found the Ds2500s a good pad until you get on track, they are quite a hard compound so wear the discs quickly & do not disperse heat very well. But put some YellowStuffs on with the DBAs & you will be fine You really rate the yellow stuff pads? I didn't get on with them tbh at all, but they do say they're not suitable for drilled discs. Quote Link to comment Share on other sites More sharing options...
Darren-B Posted November 19, 2010 Share Posted November 19, 2010 I do really rate them, when on a reasonable budget, very dusty though If I was to do it all again with the zed I would just "get it spent" and get a BBK would have worked out cheaper in the long run. I`ve blown many thousands on Zed brakes in the last 3years Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted November 21, 2010 Share Posted November 21, 2010 Just had a set of DS2500's fitted Friday and no complainsts here Obviously gone easy on them so far but I have to say I am impressed with the feel over the standard ones, much more reasuring... Quote Link to comment Share on other sites More sharing options...
