Decided!
speedy
I have the turbo grooved version and am getting a little bit of brake judder. I think this has been a fitment issue though so will get the garage to inspect them when I throw it in for a service.
The rotors themselves are ok for spirited public road use if you aren't planning on tracking the car I don't use EBC pads though - Ferodo Racing ds2500s instead.
:yawn::yawn:
Go read the Brakes subforum :thumbs:
Then set your budget and save up if need be for something decent :shrug:
I have done but there is so much choice and people give different advice- hard to know which is best...
I am only a daily driver around town...
I bought the ds2500 pads off the ZMAN and then a set of turbogrooves off eBay against his advice and they have been fine :thumbs: . I'm no track warrior though more like a highstreet poser so that could be why there alright. I personaly couldn't justify about £600 just for the front performance friction rotors. The track boys and girls will diagree though :drive1
I think £230 for a set of decent pads and discs is a little optimistic tbh. I wouldn't trust yellowstuff or anything from ebc after my experience with them on the road and at a track day, nor after seeing pictures of their pads disintegrating.
I guess they may be ok for plain road use, but I still wouldn't choose them over oem, let alone the other much better options out there.
:yawn::yawn:
Go for standard brakes with no grooves or drilled. Drilled might crack and grooved ones will skim your pads. You dont need super track discs or anything. :thumbs:
Speedy, have you checked out DBA rotors? I recently got some of the slotted 4000 series fitted (fronts) as my OEM discs were shot, and along with the Ferodo pads mentioned above they're great - powerful with loadsa feel. The rotors are c£300 for a pair :thumbs:
I use yellowstuff pads on the track and they have been fine so far. For the money they were great value. They were a massive improvement over the brembos but I've never used anything else to compare it to. I will be trying ferodo's for next year. The yellowstuff pads were fine on the roads and only get better with heat. Really pleased with them on track aswell
:yawn::yawn:
But I thought that was the whole purpose of grooved discs? To keep the pads fresh and not glazed over.
TBH your best bet though is from a trader on here like zmanalex :thumbs:
Yes your right and I may be wrong but in day to driving your pads won't glaze over nor will they hit the tenderise barrier where they need better cooling.
:yawn::yawn:
This is true, but I got the dixcels with some intention of tracking it eventually, but I guess this is n/a for this guy. Though, they do look better than flat discs imho :p
:yawn::yawn:
+1 - stick with brembo :shrug:
:yawn::yawn:
Can't you get brembo slotted discs? :p;)
:yawn::yawn:
:yawn: yeeeess and your point is? :shrug:
