trolley jack
mc
It might, but I wouldn't want to be jacking the car up many times at the sill jacking points using a trolley jack. They have been designed to be used with the supplied jack. A standard trolley jack will bend the jacking points very easily.
Best off jacking from the rear diff jacking point or front crossmember jacking point. That height jack should fit these also.
+1
I had the same problem with my axle stands re the height.......given the angle of my driveway I couldn't actually get the car high enough to use the damn things! :doh:
Hockey puck with a groove cut in it is the best way to jack the car at the sills with a trolley jack :thumbs:
will have to find a hockey puck.. in the past I've used bits of wood with a groove in to clear the seam on the sill
