oem rays
carlton x
anyone knw if a set of oem rays would fit an mitsi FTO thanx
Offset and PCD of 114.3 would be fine. 350Z bore is 66.1 and FTO bore is 67.1 so there may be 1mm that may need to be machined away on the rims.
I've had two FTO's in the past and would be interested to hear how you get on with this.
Seems obvious but just remember that if the OEM rays already have tyres on then they are gonna be too large (and probably wide) in diameter. You'll need a shoehorn a set of 235/35 18's or 225/35 18's on there to try and avoid rubbing on the FTO.
