how to guide on power steering pump replacement ?
buster
I've done this myself. Takes a couple of hours and is not that difficult, BUT I found you have to take the radiator cowl off and the top hose so you need to drain the coolant system down a bit (the long bolt on the front of the power steering pump won't come out otherwise which is a bit of a b*ll ache).
There's only two or three bolts holding the pump itself on and is fairly obvious when you get down to it.
This pdf may help
PS-pump.pdf
Unfortunately I won't be around for advice after today cos I'm off on holiday :yahoo:
